Good Combo or Bad Combo
Old May 10, 2002 | 02:54 AM
SlowStangEater's Avatar
1.84/1.50
Will those SBC 262 heads off the monzas and novas....... with 1.84/1.50 work well with the 262xe cam and the performer rpm intake? I dont have the money to buy new heads and I heard these heads arent so bad after all. Someone please help me on this.....This is the only aspect Im truly unsure of.. I just want my engine to break into the 13s with slicks and 14s without. It has a 9-1 compression and supposed performance pistons. If it is a waste of money to get any of these in a combo please let me know. What is the best combo for them heads in everyones opinion???
Old May 10, 2002 | 05:36 PM
Well I just realized that these are stock air flow numbers.............But will that combo still work?
Old May 10, 2002 | 07:22 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
1.84 isn't the best valve size, 1.5 isn't bad, but 1.94 would help out a lot more, not sure how to go about doing it though.
Old May 10, 2002 | 07:23 PM
Is there any way to make the stock ones bigger.......Instead of going out and buying new heads?
Old May 10, 2002 | 07:35 PM
Car: 99 Formula
Axle/Gears: 342
I'm pretty sure, but you'd have to buy new valves, I'm no expert on it, so hopefully someone else will step in here.
Old May 10, 2002 | 07:39 PM
Well if nothing else Im just going to stick with these heads, the 262 cam, performer RPM and a carb. I hope that helps me out.....Say Mark....Your Hooker setup.l...did you get it complete at 1 time or seperately? I want to get a 3" setup all the way back but dont know where to get the Whole thing? Any recommendations?
Old May 10, 2002 | 07:42 PM
Car: 99 Formula
Axle/Gears: 342
The cat-back I got from Jegs for $200, I got the cheapest one but it needed some fabrication.
Old May 10, 2002 | 07:43 PM
I want to get Dual Cat back with Hooker Headers.. 3" all the way back.... I want to do that when I put in this new engine.
Old May 10, 2002 | 07:50 PM
Car: 99 Formula
Axle/Gears: 342
Good luck, running 2 pipes out the back over the axle is going to be near impossible.
Old May 10, 2002 | 07:51 PM
I can do it!
Old May 11, 2002 | 09:40 AM
ORAY777's Avatar
YOU CAN DO IT!!!!
Old May 11, 2002 | 06:15 PM
So mark do you just have 1 pipe dual outlets then? Is it 3" all the way back? Would it be worth it to get Header and keep the CatBack system I have now? it is only 2 1/4 I think. But I love the setup it has. !!!!!
Old May 11, 2002 | 07:31 PM
Greg Kuhlmann's Avatar
2 1/4 to me sounds a little small... but then again i dont know... we have a 97 chevy with a true dual exhaust the pipes arent much bigger then 2" 's... it sounds really good...
but since the true duals out the rear is nearly impossible then i would atleast up grade the I pipe to 3". think about it which is going to flow better? 2 1/4" or 3" ???
Old May 11, 2002 | 07:33 PM
Oh I know it will flow better but I dont want to lose the placement of my pipes. Its original and is a B*tch to do again!
customblackbird
Aug 15, 2021 10:16 PM
86IROC112
Apr 9, 2016 10:20 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
InfinityShade
Aug 22, 2015 08:00 PM
