How to get a 305 in the 14's
Old May 16, 2002 | 10:26 PM
Randy's Avatar
I have a 1972 corvette with a 1987 305 engine (I bought the car that way). The 305 has a quadrajet GM aluminum intake mallory distributor and headers (brand unknown). The cars runs decent but is considerably slower than my Caddy STS (no track times on vette yet). How can I get this car to run high 14's all motor with stock heads and keeping the A/C power brakes etc. I assume the car has a rear gear ratio in the low 3's (3.08 etc). Thanks for your help
Old May 16, 2002 | 10:31 PM
RJR99SS's Avatar
wow....thats a pretty heavy car for just a 305. i'd really consider getting a bigger engine: at least a 350, and if you're real serious a 427 or 454. I think you'd be alot happier if you just shelled out for the bigger engine than just messing around with the 305 all the time.
Old May 16, 2002 | 10:38 PM
iroc22's Avatar
A reasonably option 3rd gen weighs just about the same.
The only solution: Camshaft.
ATH's Avatar
ATH
Car: '82 Z28
Engine: none!
Agreed... Vette need Rat motor. A 305 is bordering on blasphemy.
Aside from that, I'm curious as to why you want to keep the stock heads- if you want it in the 14's n/a, heads are a good mod to make.
Old May 17, 2002 | 12:16 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Well, you have to work on the torque end of things. Headers do major miracles for 305s. A decent cam, like a Crane PowerMax 266 or Comp XE 256, along with a port and polish job on your stock 305 heads ought to get you into the 14s, no problem.
Old May 17, 2002 | 06:42 AM
Randy's Avatar
Thanks guys, I may have to bite the bullit and build the 350 roller motor with vortec heads i have been thinking about
Old May 17, 2002 | 05:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
My combo puts me in the 14's corrected to sea level (see sig).
It's the combo, really. Heads, cam, intake, exhaust all have to work together. In a Vette, you can use long-tube headers (which I assume you already have), which helps both torque and power. A higher stall converter is also needed to allow the engine to spin up into the powerband right off the line.
If you run the stock 305 heads, get a Standard Abrasives deluxe porting kit and do everything they say to do in the instructions (they even use a 305 head for their example). While you're at it, have the intake valves changed to 1.94". Won't be quite as good as the WP's when you're done, but close.
In a '72 Vette, I'd have to vote with the Rat crowd, though...
Old May 17, 2002 | 05:27 PM
iroc22's Avatar
Yeah that should knock down 13's easily in your vette.
Old May 17, 2002 | 07:56 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
I have heard it all now, A guy asks us how to get a 305 in the 14s without even changing the heads.Then Tells us about the 100k worth of vehicles he owns:hail: If I only had his problems
Old May 18, 2002 | 02:13 PM
Vader's Avatar
My buddy, Mongo, agrees (for all you old farts like me that remember Mongo):
"Mongo say, 'Vette need 427 aluminum Rat. It original intent of car designers in '67. Mongo like less weight, more go-go. Mongo like to empty aluminum cans to make more Rat blocks. Mongo can't count past ten, so he need a car faster than that...."
If the '72 is in good condition, it might be worth recycling some old beer cans. I'd be tempted. There's nothing like 550 HP to break into the 10's.
Old May 18, 2002 | 06:54 PM
DM91RS's Avatar
Car: 91 RS
Damn...didn't realize it till now. LOL
Mongo want to be just like Vader.......
Old May 18, 2002 | 09:39 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Re: How to get a 305 in the 14's
Shoot...and here I came in thinking you meant in a thirdgen
Pete
Old May 18, 2002 | 09:57 PM
reborn92rs's Avatar
Car: 92 RS
Transmission: auto
My dad has had a 1972 vette with the origional standard 350 since the day it came off the showroom. Even with the 350ftlb of torque it has its still bad on the acceleration. Well it aint bad, it feels like its ripping the tarmac off the road, but the speedo dont move much.
I really really suggest dropping at least a 350 in to get it at least back to the origional cubes, unless it came with a 454 that is (that would suck though, cause only about 3900 came with the big block beast, somewhat worth more $$$)
No point worrying about keeping it origional either since your allready missing the origional block. So hunt around for a little, maybe youll find a deal on a 350, or big block something.
If i was so lucky as to own one, id definately be reaching for the 454 as long as the car wasnt origional.
What color is the car?
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
