Which is better air filter or foam filter?
Old May 19, 2002 | 03:11 PM
ORAY777's Avatar
In your opinion or by facts which filter will flow better a K& N type air filter or a foam filter such as the TPIS kind? Which is better performing?
Old May 19, 2002 | 03:37 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I had a foam filter once, sat on top my Stang's carb, one backfire and it got sucked right in. Though I'm sure it would be different on a TPI.
There's a reason why everyone buys K&N.
Old May 19, 2002 | 03:52 PM
scotia's Avatar
Car: 82 Trans Am
Engine: 305 Crossfire
Transmission: 200c Auto
Have heard nothing but praise for K&N filters over the years - the wire gauze ones where you add the oil. Seem to remember one of the car mags ran various tests with air filters a few years ago : standard paper ones , foam ones and the mesh ones : the mesh ones , infact it was a K&N , came out tops in all respects ie. Longevity , airflow , stopping particles etc etc , I think you get a lifetime guarantee with it as well. The K&N was one of the more expensive ones , which is still the case today , but if I was gonna get an aftermarket airfilter , it would be a K&N - they have a good reputation over here.
Old May 19, 2002 | 03:54 PM
scotia's Avatar
Car: 82 Trans Am
oh , and I seem to remember it was worth an extra 3 bhp !
Old May 19, 2002 | 05:03 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I ran foam filters on my VW for about a month. They hold water between the foam cells and have a tendency to implode. I've had K&N's on it for 3 years now. Guess which I think is better.
Old May 19, 2002 | 05:12 PM
Biochem's Avatar
Car: 2002 SOM z28
K&N would be better than a foam (seat cushion modification?) filter. But then again, a stock air filter element would probably flow more air than 90% of the people on this board need anyways...
Old May 19, 2002 | 08:46 PM
camaro6spd's Avatar
yeah....i was lucky my car came with K&Ns...otherwise i would have never bought them.....
Old May 19, 2002 | 09:10 PM
2vmodular's Avatar
be aware that if you over-oil your k&n filter, there is a good probability that you will damage the MAF sensor (Mass Air Flow). Replacement MAF sensors are not cheap.
Old May 19, 2002 | 11:08 PM
breathment's Avatar
yup, i once overoiled a filter on my old Integra, and i took the intake hose off one day for some reason, and the inside of it was covered in sticky red oil!!
Old May 19, 2002 | 11:56 PM
Fred91TA's Avatar
Car: 1991 Trans Am
Transmission: 4L60
One of the car magazines just had a write-up on this topic. I think it was Car Craft or CHP, but as far as flow and dyno tests, there's hardly any difference between any of them.
Old May 20, 2002 | 09:50 AM
camaro6spd's Avatar
...yep....just like dirtbike filters.....man for the size of the motor....the filters on DB have more Surface area then Big Block V8....and they are cleaned just like K&Ns and they only go for $20-$25....while K&Ns go for 50?
Old May 21, 2002 | 07:59 AM
ORAY777's Avatar
Hey Camaro6spd. You should go for a 350 instead of a 305. Lots more torque than a 305.
Old May 21, 2002 | 03:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I know a guy with an import; told me he's got a cold air intake, and we were talking about what a pain it is to clean the filters. He has a filter similar to a K&N, but doesn't use cleaner or oil on it! He just rinsed his with water and put it back on the car. Anyone heard of a filter like this??? I think he's doing it wrong!
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Derick15
Sep 17, 2016 05:28 PM
Thornburg
Sep 1, 2015 03:39 AM
