p/s and alternator bracket bolts broke in head
Old May 28, 2002 | 09:38 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
ok...i was driving and th power steering went out and the car overheated so i stop and pop the hood...belt came off. then i noticed all the 3 bolts in the head (drivers side) broke off in the head itself. how the hell do i get these out?
Old May 28, 2002 | 09:54 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
ouch... most likely the only way is to drill them out and retap the holes.
Old May 28, 2002 | 09:57 PM
Car: 88 Camaro SC
Engine: SFI'd 350
if they broke off at the surface you could possibly, maybe, use a small rotery cutting bit to slot them and use a screw driver to turn them. Worked with a broken bolt in my bros starter. Longshot, though
Old May 28, 2002 | 10:30 PM
Engine: 5.7L
thanks for the advice....ill try that...if it doesnt work i just picked up a screw extractor which i gotta drill into the stud and tap that thing in and put a nut sorta thing around it and hopefully it will come out.
Old May 29, 2002 | 04:56 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
there is a tool it is like a reverse drill bit that will grip it and turn it out. Just a thought.
Old May 30, 2002 | 12:36 AM
32789RS's Avatar
Your best bet would go to the hardware store and get an easy out,. Wich was refered to in the previous post as a reverse drill bit.
Old May 30, 2002 | 12:49 AM
Morley's Avatar
Actually they do make left hand drill bits, and mechanics do use them for screw extracting.
But the best bet is to just drill it with about a 5/32" bit and use a #3 easyout to back it out.
~M~
Old May 30, 2002 | 07:04 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
What is it with these Iowa guys and there 283 327 combos???
32789RS, what kind of HP you turning ? You running that on the street? 4.10 gears....what pistons you running if you dont mind me asking.....
How the heck do ya bust all 3 mounting bolts..
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
mcquigg
Aug 13, 2015 02:26 PM
