bent cam !?!?!
Old Jun 11, 2002 | 05:06 PM
trans_am_racing's Avatar
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
bent cam !?!?!
i dont know how possible it is to bend a cam but i think mine is.....i cant get the dang thing out for the life of me....anyone else ran into this problem?
Old Jun 11, 2002 | 05:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you take off the mechanical fuel pump?
All the lifters out?
Distributor out?
Okay, not trying to suggest anything about you, just covering the bases.
Old Jun 11, 2002 | 05:44 PM
Vader's Avatar
Did you reinstall the cam sprocket and try to turn it by hand? It should move easily after all of 5-7's suggestions. If it spins freely but won't slide out, you may have a bearing that is grooved by a burr on the cam, effectively locking it in place. If that's the case, you'll be looking at new cam bearings.
Old Jun 11, 2002 | 05:47 PM
Car: 2000 firehawk
Engine: ls1
thanks guys
yeah i had everything out and all... finally got it out..... the idiots that put it in before i got the car hammered the f*** out of it on the end so now its definately new bearing time and a rebuild to get all of the damn metal flakes out
Old Jun 11, 2002 | 06:36 PM
Car: 2000 firehawk
Engine: ls1
junk cam now
heres a pic of the cam that i pulled
http://www.rochelle.net/~playa01/fuedupcam.html
Old Jun 11, 2002 | 10:44 PM
83z28500ci's Avatar
my cam wont come out ehthier. i can get it out till i see about
3 1\2 lobes then it wont come out no more and it wont turn all the way around. u think i should take of the mechanical fuel pump so the rod can go down?
Old Jun 11, 2002 | 10:47 PM
Vader's Avatar
How the fork did they even get that installed? Are you certain the cam wasn't hitting the rear plug of the cam bore? Damn!
Car: 2000 firehawk
Engine: ls1
yes youll need to, the part of the cam where it sits on the bearing will be held up by the mechanical pump......
Old Jun 12, 2002 | 12:08 AM
RJR99SS's Avatar
man...how long did that engine run with that chewed up thing in there?
Old Jun 12, 2002 | 12:32 AM
Car: 2000 firehawk
Engine: ls1
Not very about a week tops : (
Old Jun 12, 2002 | 08:26 AM
a73camaro's Avatar
I believe that the installer of the cam tried to install the cam from the rear of the engine (IMPOSSIBLE TO DO). Since the cam wouldn't go, he got out the attitude adjuster and when to town.
Un-flippen'-believable!
Old Jun 12, 2002 | 10:06 AM
Beefy89's Avatar
Re: junk cam now
[QUOTE]Originally posted by trans_am_racing
[B]heres a pic of the cam that i pulled
Unreal!!!!!!!!!!!!!!!
Old Jun 12, 2002 | 09:34 PM
camaro1982's Avatar
LMAO!!! sorry...just had to laugh my *** off there. i may not know alot about engines but i know enough not to beat the **** out of a square block to get it into a round hole.lolz
Old Jun 12, 2002 | 11:11 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Thats crazy!
Old Jun 13, 2002 | 10:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If the cam won't come out, try turning the crank a few degrees... rods can be within the "volume" occupied by the cam's bearing journals as it slides out.
Old Jun 13, 2002 | 03:02 PM
83z28500ci's Avatar
i got the cam out. i had to take the fuel pump off,but it slided rite out
Old Jun 13, 2002 | 04:04 PM
Guest
Guest
Posts: n/a
Yea, someone beat that with a hammer. The rear plug will just shine it up, it doesnt do damage like that.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jorlain
Oct 8, 2015 01:57 AM
dbrochard
Oct 3, 2015 12:43 PM
dbrochard
Sep 7, 2015 09:41 AM
masonta
Sep 1, 2015 06:40 PM
