Would this work?
Would this work?
Im looking for a cam that i dont have to mess with the heads to use. Will this work? If not what would i have to do for it to work? What kind of power gains should i get with it?
350 ZZZ Cam specs.. Lift- .480/.480 w/1.5 rockers, 235/235 duration, 114 Lobe Seperation
Wouldnt this work pretty good??
Thanks,
Jesse
Thanks,
Jesse
guestimate
Whats your guess to power id gain? 5hp? 10 hp? ect... Im tryin to run 13s consistent. My best so far is 13.99. i usually run a 14.1- 14.2
Thanks, Jesse
P.S. A stall is in the NEAR future as well.
Thanks, Jesse
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
That cam is only medieoker. GM only used it in their crate ZZZ
or ZZ3 motor for a little while. The revised ZZ4 cam with 208/221
.474/.510" /112 makes just as much hp and a lot more usable torque with better mileage too.
The ZZ4 or the "Hot Cam" are better GM factory choices for power.
All cams work much better with head mods.
Air flow is where it's at. Get out the Die grinder.
All these cams require specific improved valvetrain components
to work. The stock stuff won't cut it here.
Terrell351
Jun 13, 2021 01:13 PM
