Forgot a plug?
Old Jul 11, 2002 | 10:55 AM
THE SANDMAN's Avatar
Car: 1983 Camaro
Engine: 5.7
Forgot a plug?
I think the reason my oil psi is only around 30 is because that the plug under the rear main cap is missing. Is there anything i can do to fix this problem without ripping out the engine? Please help.
Old Jul 11, 2002 | 10:56 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
NOt sure about the plug, but 30 psi seems ok to me. 10 psi for every 1k rpms is what you want to be at.
Old Jul 11, 2002 | 11:01 AM
86_iroc-z28-350's Avatar
ok 30 psi is just fine if that is at idle. but if thats at wide open your oil pump may be a lil worn. also how many miles does it have. My new motor has 14,000 miles on it with only 3,000 on the xtreme energy comp cam. My oil pressure stays at 60 psi at all times unless its realy hot out and its at idle it will go around 25-30.
Old Jul 11, 2002 | 11:03 AM
Car: 1983 Camaro
Engine: 5.7
The motor is brand new with no miles on it yet and it has a brand new melling oil pump and screen.
Old Jul 11, 2002 | 11:33 AM
Morley's Avatar
Unless you built the engine from a bare block or actually removed the restrictor plug, it should be there. But if it isn't, I THINK you can get to it by just removing the oil pan.
Old Jul 11, 2002 | 11:54 AM
ok if it is brand new and only 30 psi i would fix it, cuz when u break it in and it gets warm the pressure will drop and at idle u wont have enough to feed the engine.
Old Jul 11, 2002 | 02:08 PM
Car: 1983 Camaro
Engine: 5.7
Anyone know if i will be able to just get the pan off and get to it without taking out the motor?
Old Jul 11, 2002 | 08:49 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Mine runs at 60 when cruising and about 25 at warm Idle with a mechanical gauge..I would also think 30 on a new motor is way low. I cant help ya with the plug, sorry
Old Jul 11, 2002 | 08:58 PM
ede's Avatar
ede
if there is a plug missing from a oil passage yopu need to install it and you sould not start the engine without it, reguardless of what oil preasure you have. without the plug oil is bypassing something it should be going to.
Old Jul 11, 2002 | 10:09 PM
Nordbert's Avatar
Remove the oil pressure sending unit and push a long wire
( your engine's dipstick will probably work ) into the oil
gallery until it stops.
Measure the depth the indicator went into the block.
If it stops at 8", then the plug is place I checked it on
a Chevy 350 a few months ago.
Old Jul 12, 2002 | 12:00 PM
Car: 1983 Camaro
Engine: 5.7
Thanx Nordbert i did what you said and it stopped at about 8 in. so the plug is in place. :hail: Now i have to figure out why i still have only 30 psi of oil pressure.
Old Jul 12, 2002 | 04:53 PM
Engine: 406
Hook up a mechanical gauge .....yours could be off..especially if yours is stock
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
