dual quad carb recomendations
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
can anybody give me part numbers for carbs that would go onto an offenhauser dual quad intake.
it is a squarebore, i believe.
and it will be on a 400 sbc with the motown 220cc heads with a nice big cam
thanks
andrew
thanks
andrew
didn't you read the replies you got the last time you ask about this? i believe several carbs were mentioned. call 1-800-345-4545 and tell them what intake you have and what size carbs you want.
Car: 1985 Z-28
Engine: a big one
yes, i have reviewed that last thread that i have started. sorry for the double questions.
but my main concern is that the way the holley bowls are situated they may not clear each other.
I guess that is my main concern. and that 390 holley suggestion sounds promising. is that 390 CFM? or is that an arbitrary number.
and i take it i am looking for center hung bowls right? does holley make a set of carbs for a dual quad setup?
also can anybody point me in the direction of some literature on dual quads?
also, tuning would be greatly made easier if i were to have a good O2 sensor, correct?
another question is, if i were to custom fabricate my own throttle linkage, i can get one pair of butterflies open while crusing, correct? and i am not worried about the "complexities" with such a linkage, i am studying to be a mechanical engineer by the way, and this sort of stuff is right up my alley.
thanks for your info
andrew
andrew
yep 390 is the cfm, not sure if they're center hung or not, my 450 isn't, but there's no reason you couldn't buy a junk carb at a swap meet and swap to center hung bowls if that's what you want.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Mount them sidewise so the float bowls are on the sides. Still makes it hard to tune since air mixture screws are now on the inside.
Ditch the dual 4's for a nice single.
Why don't you just mount 2 TBI's on it.
Car: 1985 Z-28
Engine: a big one
i would mount them sideways, but there is a wall in there that seperates the banks....
the tbi would bolt up to a squarebore intake? this could be interesting...
to do the TBI, would i be able to splice in wires in the same wiring harness to run a second TBI unit?
with a dual TBI setup, would i be able to get power, i always read people bashing TBI
This TBI idea is pretty interesting stephen, i should look into it some more.
Car: 87 IROC L98
They should sell adaptor plates to mount it to a spreadbore. If not, it wouldn't take much to make them.
I have no idea on how to wire up 2 TBIs but I've seen it done on a BBC so I know it's possible. I think it might have been a kit from JET.
Car: 1985 Z-28
Engine: a big one
are stock TBI units two barrel or four?
holley makes a kit that has a 4 bbl style TBI and it bolts up to a square bore intake.
codeysabatini
Nov 10, 2015 04:07 PM
