View Poll Results: how fast could a 6.6l w/ported tpi intake,mild cam &headers/3in exh go w/ prom chang?
15 seconds
26.32%
14 seconds
10.53%
13 seconds
21.05%
12 seconds
42.11%
Voters: 19. You may not vote on this poll
smell?
Old Jul 22, 2002 | 11:26 AM
kvu's Avatar
kvu
smell?
If I tune my car a certain way it'll get this wierd smell at idle.I do notice the blms go lean.I can't understand what would cause this.So I posted it here for you to take a stab at it.My ideas are too much/little timing,too lean,too big of injectors for the ecm to handle(30lbhr) or the catalayic converter overheating??
Old Jul 22, 2002 | 03:06 PM
funstick's Avatar
if it smells like a lit match then yr in toruble. it means yr cooking the catalytic converter. in the abscence of excess feul to convert
nox2 into water the noble metals will catalize themselves. running lean with a cat is bad news. this might be yr smell. fatten up the idle a bit.
Old Jul 22, 2002 | 04:29 PM
goneracin's Avatar
i guess it would depend on the smell. If its lean enough to get a lean miss, you would get a bad smell out of it also, almost like being to rich. Too much idle timing will also make it stink, esp if lean.
Old Jul 24, 2002 | 09:56 AM
kvu's Avatar
kvu
It kind of smells like when exhaust is new and has a coating on it.The exhaust is not new though.It's only after I change something in the chip.I can't pinpoint the cause.My intake is painted but it does'nt smell even in 100F temps.I'll figure it out but help helps.Would the catalayic converter breakup if it was exposed to a prolong lean condition?
Old Jul 24, 2002 | 10:32 AM
kvu's Avatar
kvu
I dont get how a 400 sbc would get a slower time than a stock 305/350,with an optimised prom
Old Jul 24, 2002 | 08:04 PM
kvu's Avatar
kvu
anybody?
Old Jul 24, 2002 | 09:48 PM
87_TA's Avatar
Well it all comes down to air flow,A engine is just an air pump.
The more air it can pump the more power it can make .
With the stock intake and runners on a larger displacment
engine is going to lower peak power even more ,you should have plenty of torque - if you can gear and hook to take full advantage of that torque than you should not have a problem running
mid to lower 13's.
Your mph is a true indicator of what a car is capable of,HP calculators like the one at mustang corral are very accurate
of possible ET - both of my vehicals are with in 1 tenth of
corrals estimate .
It come down to if you can 60ft what your HP is capable of and gear to take advantage of peak power in all 3 gears with out over rev in top crossing the line.
Old Jul 25, 2002 | 02:32 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
So, I want a clean- smelling idle. Suggestions?
Old Jul 29, 2002 | 03:45 PM
kvu's Avatar
kvu
huh?
Old Aug 5, 2002 | 05:50 AM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
been here-check your a/c evaporator housing. are you running headers? with mine, the plastic would get hot enough to never really melt but the frickin thing gave off the burning smell i think you are describing. then i grabbed an evap.housing heat shield off a phord ranger and it fit t!ts. and the smell went away. then i took the whole thing off and replaced it with a real metal heater only box. hope this helps.
Old Aug 5, 2002 | 10:38 AM
kvu's Avatar
kvu
Thanks grumpygreaseape, did figure it out a while ago.It was the cooling fan switch plastic plug.I put some header wrap on and it never burns now.I guess when the headders heated up more than usual the plastic burned.
I would like to know how that car(in poll) would go slower than stock,anybody?
Old Aug 6, 2002 | 02:43 PM
NAS's Avatar
NAS
sounds like at least a 13high second ride
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
