Could someone please post a picture of their V-belt F-body?
Old Jul 22, 2002 | 01:52 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
I need the belt routing... thanks.
Old Jul 22, 2002 | 03:47 PM
1986redbird's Avatar
hope this helps:
Attached Thumbnails Could someone please post a picture of their V-belt F-body?-belts1.jpg
Old Jul 22, 2002 | 03:48 PM
and this:
Attached Thumbnails Could someone please post a picture of their V-belt F-body?-belts2.jpg
Old Jul 22, 2002 | 04:30 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Thanks very much!
Old Jul 22, 2002 | 08:33 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
Is that a serpentine belt running the alternator??? that's a new one me. mine is similar but all of mine are "v"belts (I'd post a pic but I upgraded to XP and my scanner's driver no longer works and the company that makes it website is down)
Old Jul 22, 2002 | 08:49 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
Don't think there's anything special about that alternator belt. It routes from the alternator, around the H2O pump pulley (in the middle), down around the crank pulley, and then back to the alternator.
the smog is easy and goes from the smog pump around the front slot in the H2O pulley only.
The power steering pump belt is different in the picture than on my car. so don't want to mix you up. But...mine goes around the PS pump pulley and then around the crank pulley(only) in the far back slot.
Do not use the middle crank pulley spot for the PS pump, or your H2O pump pulley will hit it. Use the back one
I think the middle one is for the AC belt, but I have no AC belt on my car. Have a new compressor, but no belt. Doesn't make much sense I know, but I can't figure out how to remove the AC system easily, and don't want to put a belt on it because of all teh expenses that come with AC.
Hope this makes sense, and helps.
By the way, this routing is for a 305 4bbl.
Old Jul 22, 2002 | 10:33 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
This is how my V-Belts are routed, which is how they would be routed on the original 305 4-barrel.
Attached Thumbnails Could someone please post a picture of their V-belt F-body?-v-belt-routing.jpg
z28_AJ
Aug 27, 2015 08:59 PM
chubsworth
Aug 26, 2015 02:34 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Linson
Aug 21, 2015 02:12 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
