so i get my new steering box from the junk yard and.........
Old Jul 23, 2002 | 08:16 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
the guy dropped it in the sand. so the sand got into holes where the hose go i think. but then the guy took it and cleaned it really good so it looks ok. My question is should i try put something where the holes are that the fuild goes in, like to try and rinse it better to get the sand out if there is any? someone also told me to use brake cleaner. also the steering box has resistance when i try and turn it by hand,is that normal?
Old Jul 23, 2002 | 09:13 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
How did the guy clean it? I would double check it just because it would suck if you got it going and then discovered that it is jacked.
Brian
Old Jul 24, 2002 | 07:18 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
I don't know what kind of solution he used but i heard him using compressed air. it looked alot better than it did. ill post a pic later today.
Old Jul 24, 2002 | 11:02 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
here is the pic. where the white arrows are is where the sand got in. If i clean it out good will it be ok to use? and also what should i use to clean out the holes?
Attached Thumbnails so i get my new steering box from the junk yard and.........-11.jpg
Old Jul 24, 2002 | 04:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I wonder if the compressed air forced the sand even further into the holes. Could you just fill the box with p/s fluid, and dump the fluid out?
Reminds me of when I got some brand-new-looking rotors off a camaro with "blown motor" written on the windshield- I took off the rotor, saying repeatedly "don't drop the rotor, don't drop the rotor, don't drop the DAMMIT!" and right into the sand. Oh well.. I guess the bearing had to be replaced anyway.
I passed up so many quick-ratio steering boxes because someone had taken the p/s pump and left the hoses open to the sky (and rain and bugs and dust)...
Old Jul 24, 2002 | 04:29 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
what im trying to figure out is i can rinse the box with p/s fluid again to try and get the sand out. But if i put it in how bad will some sand mess up my p/s system?
Old Jul 24, 2002 | 07:02 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Can't you pop that top silver cover off and then flush the guts?
If he just used compressed air he probably just pushed the sand in further
Old Jul 24, 2002 | 08:05 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
what top silver cover??
Old Jul 24, 2002 | 09:36 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
try putting a hose on the "in" end (dont remember wich hole) that is attached to a contaner filled with p/s fluid and presserizing it with compressed air. that should blow everything out. (and make a big mess- better get the safty goggels )
Old Jul 24, 2002 | 09:53 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
how thick is the ps fluid, isn't ps fluid the same as hydraulic fluid?
anyway, why not trying a thinner fluid to flush out the sand. like gasoline or turpentine?
Old Jul 25, 2002 | 04:23 AM
Rob P's Avatar
Engine: ZZ4TPI
There is a silver plate on the top of the steering box, four bolts with an adjustment screw in the center. Hard to miss.
Old Jul 25, 2002 | 08:59 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
I just want the sand to mess up my car. I will try compressed air again. and i will try and take the cover off. also i have 30 days to bring this thing back if i don't think it is ok to use.
Old Jul 25, 2002 | 09:00 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
i meant i don't want the sand to mess up my car
GTAman
Jul 3, 2024 07:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
