good idea......bad idea?
Old Jul 25, 2002 | 06:18 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
Is it a good idea or bad idea to do the following things?
1. sand the surface rust off the rear axle
2. paint the rear axle, or undercoat it
3. sand surface rust off and paint/powdercoat anti-sway bars
asking on number three to make sure bushings will still fit right
Old Jul 25, 2002 | 07:03 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I can't see it being a problem.
Old Jul 26, 2002 | 12:06 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Go for it.
Old Jul 26, 2002 | 12:08 AM
Car: 86 z28
Get yourself some quality undercoating.
Old Jul 26, 2002 | 11:08 AM
InTeRcEpToR5.7l's Avatar
no reason anything will get hurt, id just get it clean and undercoat it, wouldnt worry about perfection...
Old Jul 26, 2002 | 11:12 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i completely cleaned my rear antisway bar down to shiney metal and painted it black, bushings still fit fine
Old Jul 26, 2002 | 10:20 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
Cool,
Thanks for the reassurance.
As for the axle- before undercoating, should I get all rust off? Or does it matter?
I also want to change the cover- mine has a couple small dents in it, and I am sure the fluid could use changed.
here is another good idea-bad idea:
1. Driving with a slooow leak from back of valve cover?
I get white smoke on start-up, could valve cover be the problem or does my smoke come from deeper inside the engine?
Old Jul 27, 2002 | 05:17 PM
cfabe's Avatar
White smoke is associated with water, which would indicate a serious internal engine failure.
If your smoke however, is more blue then white, it's likely oil smoke. Since you say it's just on startup and almost every older SBC has startup oil smoke to some degree from leaky valve seals, I'll bet this is whats happening to yours.
The slow leak on the valve cover... its not really going to hurt anything, however it will eventually get worse. It's also not that hard or expensive to fix, either.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
mdtoren
Aug 23, 2015 12:52 PM
Cripley
Aug 17, 2015 03:35 PM
BurlyChev
Aug 16, 2015 09:08 PM
mdtoren
Aug 16, 2015 05:45 PM
