305 ideas
Old Jul 27, 2002 | 02:04 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
305 ideas
Look, I just want to say right now that I'm going to college and furthering my education in order to make the big bucks later. Then I can afford the big engines. Right now I just want to mod my 305 just so I can have a Quick car. I'm not getting a 350. I've just got a 305 with 60,000 miles on it. And I'd rather see a modded 305 than a modded 350...I'm for the underdog...
ok ok ok ..... ...
now ....how does this sound
going down to 3.73 gears...
305
quadrajet
performer intake (non-egr)
Comp Cams XE262H-10
3000 rpm stall
416 heads (milled for higher compression)
Accel supercoil
Edelbrock TES
Catco universal
flowmaster 80 series exhaust
turbo350 with B&M shiftkit
Dual snorkel Ram-air
Now with those heads....if i didnt port them myself...could i still fit a 1.94 valve in..........in place of 1.84....???
Rob..
i'm just looking for around 250 - 75 horse....
after these mods i think i'd be lucky to hit... 225 hp...
Old Jul 27, 2002 | 03:30 PM
1986redbird's Avatar
I got 282 hp @ 5000 and 340 trq @ 3500, I ran it with stock heads because I don't have a flow file for the 416's. I used everything else you mentioned, I imagine it would be higher with better heads.
Old Jul 27, 2002 | 03:32 PM
Car: 1983 Z28 Clone
Transmission: TH350
THANKS BRO..!!!
i'm just looking to freshen up the motor....
thanks ...
Rob
Old Jul 27, 2002 | 03:45 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you're going with an Edelbrock intake get the RPM. That Peformer is a waste with 3:73s and a 3000 stall.
I just got the Stealth intake idle-7k rpms.
Old Jul 27, 2002 | 03:48 PM
Car: 1983 Z28 Clone
Transmission: TH350
I already have the performer.. on my 78...........actually i think the stock was better...
the RPM isnt that expensive though.........
i'm coming into some money at the end of this month.. soo.. i just want to get all my parts......together...
scrap the performer....and go RPM....
added to list.....
thanx
Old Jul 27, 2002 | 04:01 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
are you copying me? that combo should be pretty good, especially if you port the heads.
Old Jul 27, 2002 | 04:02 PM
Car: 1983 Z28 Clone
Transmission: TH350
what do you think about stall speed though... 3000 might be a little high dont you think ???
Old Jul 27, 2002 | 04:06 PM
Car: 99 Formula
Axle/Gears: 342
Yeah, for a DD that might be too much, a little less should be fine. I'd go with maybe a 2600 or so.
The Stealth intake is like $50 cheaper than the RPM, Summit has it for $109, Jegs $170, go figure.
Old Jul 27, 2002 | 04:07 PM
Car: 1983 Z28 Clone
Transmission: TH350
ill check the stealth..right now ..at summit............
and the stall
Old Jul 27, 2002 | 04:43 PM
Car: 1983 Z28 Clone
Transmission: TH350
well... that cam is a little expensive....what about the summit cam and lifter kits....
what summit cam would be good.... i'm having trouble ..finding something.............................
BMM-20404 GM: 1968-81 TH350, 1965-91 TH400, Tork Master 2400 torque converter $149.95
WND-8016 Chevrolet: 262-400, idle to 6,800 rpm, aluminum, Stealth, intake manifold $109.95
$109.95
Old Jul 27, 2002 | 04:52 PM
Car: 99 Formula
Axle/Gears: 342
$109.95
I know what you mean about the Summit cam, they're cheap. And I was going to go the same route. And I was informed on here, that the Summit cam's are based on 80s technology. So, in short a cam is a great way to increase power, and is a lot of work, so don't try to cheap out on it. Spend the money on a good one.
Old Jul 27, 2002 | 04:53 PM
Car: 1983 Z28 Clone
Transmission: TH350
thanx..............
Old Jul 27, 2002 | 05:11 PM
Car: 1983 Z28 Clone
Transmission: TH350
ok here we go...
CCA-12-238-2 Chevrolet: 262-400, 262/270 degrees duration, hydraulic, Xtreme Energy camshaft $96.95
* Duration at .050 in. cam lift: 218 intake/224 exhaust
* Gross valve lift: .462 in. intake/.469 in. exhaust
* Lobe separation: 110 degrees
* RPM range: 1,300 to 5,600
* Noticeable idle
$109.95
Total
$356.85
Not bad..
Old Jul 27, 2002 | 05:39 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Go for the Stealth instead of the Performer RPM. The RPM is difficult to get under the hood of a thirdgen.
The XE262 is a little iffy in my books. An XE256 or Crane PowerMax 266 or 260 might work better. It is simply a matter of lift with stock valve springs, and engine vacuum at idle. Some folks like the 262 and with your higher stall converter you might be OK. The Crane PowerMax cams are a newer grind than the Comp XEs, though.
It will be an excellent little 305
Old Jul 27, 2002 | 05:43 PM
Car: 1983 Z28 Clone
Transmission: TH350
thanx for the input on cams... i really dont want to screw that up..
I want something that is noticible at idle....but...t hat comes secondary.. i guess ..to the power ..that i want.. I definately love the sound of a good cam.
This car is going to be running the 1/8 about 10 times a year bracket racing also i might add....
Ill take a look at the cams you suggested..(as you can tell i dont know much about cams)
Thank you.
Old Jul 27, 2002 | 05:47 PM
with my setup and a 1.5" tall open element i only have like .5" of hood clearence.
1992 Camaro RS LO3/700R4
Holley 600 Double Pumper, Weiand Stealth Intake Manifold, Accel Distributor and Coil, Hedman Headers and Modified Hedman Y-Pipe(Ported and 3" Pipe), Straight-Pipe Cat, Flowmaster 3" 2 Chamber Race Muffler, 180º thermostat, 3.73 Posi, Boxed LCAs, Kumho 255/50s, Polyurethane Transmission Mount, Stewart Stage 1 Water Pump, B&M SuperCooler, and Proform Shift Light.
Old Jul 27, 2002 | 05:48 PM
Car: 1983 Z28 Clone
Transmission: TH350
Darn ...!!! guess ill have to get a scoop
Old Jul 27, 2002 | 05:51 PM
Engine: 305-4v
I just ported and polished a set of 305 heads two weeks ago. Go here and check out my thread. It's even loaded with pictures and lots of expert advice from our gurus
https://www.thirdgen.org/techbb2/sho...hreadid=117410
Old Jul 27, 2002 | 05:55 PM
Car: 1983 Z28 Clone
Transmission: TH350
yeah.. those heads are killing my mind.... I've never worked on heads to that extent...and well... i'm scared to mess em up.. ill check out your post....
Old Jul 27, 2002 | 05:57 PM
Engine: 305-4v
NO WORRIES MAN!!!
YOU CAN DO IT!!! I even did it
No kidding, it is not very hard. Just follow what I did and you will be A-OK!
What is really cool is getting an extra 30 hp and being able to reuse them on your next 350 or 400 V8. Mmm, mmm good
Old Jul 27, 2002 | 05:58 PM
Car: 1983 Z28 Clone
Transmission: TH350
if you dont mind me asking .. what was the final cost of "project Port"
Old Jul 27, 2002 | 06:02 PM
Engine: 305-4v
I purchased the Standard Abrasive Deluxe head port kit and it cost me $110 Canadian. Then I had to rent an electric die grinder for $50/week, and it took me a week. I also had to spend about $40 on carbide cutting bits.
In retrospect, I would not bother with the Standard Abrasives kit. I'd just buy the four carbide cutters I suggest in the thread and rent the electric die grinder. They are all you actually need.
Read the entire thread through and if you need more advice, let me know.
No kidding, you CAN do this
Old Jul 27, 2002 | 06:04 PM
Car: 1983 Z28 Clone
Transmission: TH350
i'm sure ill be contacting you.
thanx man
pimp2303
Jul 27, 2017 02:03 PM
Fast355
Dec 2, 2016 06:33 PM
Derick15
Sep 17, 2016 05:28 PM
GouldyGTR
Aug 21, 2015 10:43 PM
