Starter Clicking, Sometimes
Old Aug 14, 2002 | 01:50 AM
DEATH88305's Avatar
Car: 1988 IROC CAMARO
Engine: 5.0 F.I.
Transmission: 700 R 4
FIRST OF ALL, THE STARTER IS ONLY A FEW MONTHS OLD, BUT RECENTLY IVE BEEN EXPEIRENCING THIS CLICKING PROBLEM,
SOMETIMES WHEN I GET IN MY CAR N TURN THE KEY IT JUST CLICKS, THEN I REPEAT TRYING TO START IT WITH IT CLICKING 3 4 5 6 TIMES THEN ITLL START, BUT OTHERTIMES IT START NORMALY....... THANKS
Old Aug 14, 2002 | 02:07 AM
jrm's Avatar
jrm
make sure the positive and negative cables are tight on the battery and starter. Sounds to me like a bad connection....
Old Aug 14, 2002 | 02:12 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
could be a bad starter, they have been known to have bad ones right out of the box, but more likely, a loose connection
also, do you have any oil leaks?, if so starters do not like being coated/soaked in oil, it drastically decreases their life expectancy
also a lot of short trip driving, puts more wear and tear on them, you know what i mean, start car, drive for 5 min, stop, start car........and so on
Old Aug 14, 2002 | 04:06 PM
racerx004's Avatar
Could be the solenoid. I believe it is mounted on the starter.
If it go's you will also get this problem.
Old Aug 14, 2002 | 05:08 PM
83 MidniteZ's Avatar
Experiencing the same problem with my car. I am running the Powermaster XS starter and a remote solenoid. Stumps the hell out of me, I've checked my connections about 5 times.
Old Aug 14, 2002 | 06:43 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I have the same problem. I just talked to a mechanic yesterday and he said if I take the sleeve of of the starter celeniod it will have two contact points. One will stay with the sleeve when you pull the sleeve off and the other on the celenoid. He said look at the contact point on the celeniod and it will probably be burnt. He said you can take it off and turn it around for better contact.
I have not tried this with mine yet, but I plan to. This guy has been quite knowledgable in the past. So I will give it a try.
Bill
Old Aug 14, 2002 | 06:46 PM
DEATH88305's Avatar
Engine: 5.0 F.I.
:rockon: I JUST ALSO HAD A THOUGHT, IM PRETTY SURE THERES AT LEAST ONE RELAY ON THE STARTER, ONE FOR OVERTEMP, WONT TURN OVER IF OVERHEATED, BUT MY PROBLEM EXISTS AT ANY TEMP, COLD IN MORNING , AFTER A SHORT DRIVE ECT.
BUT IT WOULDNT HURT TO CRAWL UNDER THE THING N CHECK THE WIRES TO THE STARTER FOR CLEANLINESS N SECURITY.
THANKS......NE MORE INPUT WOULD BE GREATLY APPRECIATED.
Old Aug 14, 2002 | 11:33 PM
CaysE's Avatar
One more input. Ease up on that caps lock. <--capsglasses
Are you trying to start the car or is the key just in the Acc position?
Old Aug 16, 2002 | 11:56 PM
DEATH88305's Avatar
Engine: 5.0 F.I.
yes of course it was trying to start it, the accessory position is back not forward.........thanks for the input though.........
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Linson
Oct 1, 2015 09:50 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
