heater core question
Old Sep 17, 2002 | 01:42 PM
RedZ28Chik's Avatar
alright..heres the problem the other day anti-freeze was leaking into the passenger side floor and windows were fogging up really bad..so immediatly i figured it was my heater core. however its also leaking antifreeze underneath my car and the antifreeze that was on the ground was a little foamy. i noticed a squealing comming from the hose people told me it was probably just the hose and not my heater core since it was also leaking underneath my car. any suggestions?
Old Sep 17, 2002 | 01:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ummmm..... change the hose? tighten the clamp? see if it goes away?
Old Sep 17, 2002 | 02:03 PM
Vader's Avatar
What RB is saying is that it is possible that a leaky hose conneection can allow coolant to run into the passenger compartment and drain out your HVAC ducting/core case. If you're lucky, that's the problem. However, accessing the hoses is half the difficulty in changing the heater cores on our cars, especially the V-8s.
Old Sep 17, 2002 | 02:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That would be it... the hose end is almost up against the firewall, and there's this gasket sort of thing there that deteriorates, so if the hose is loose or whatever, it will squirt coolant past the seal into the car... yuck...
Always try the obvious first.
It's not that hard to do the hoses though, just use a box cutter to slit the hose lengthwise on the nipple. Don't try to pull it or otherwise use lots of force, you'll just end up breakign the nipples off of the heater core and creating a leak where there maybe wasn't one before.
Old Sep 17, 2002 | 02:58 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Try the 6 inch italian? LOL you sicko
Old Sep 17, 2002 | 03:01 PM
RedZ28Chik's Avatar
hey chuck im not the only sicko lol
Old Sep 17, 2002 | 04:10 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I have also done the heater core change out and I would definitely try the hoses first. However; if it was a larger leak in the passenger compartment than it was on the ground, then your problem will be the heater core. The holes in the fire wall are not that big to leak a large amount of coolant into the passenger compartment with the heater core in place.
Old Sep 17, 2002 | 09:36 PM
RedZ28Chik's Avatar
alright guys the problem is now fixed and thank *** it wasnt my heater core just tightened the screw/clamp by the firewall and magically the problem has stopped thanx for the advice
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
