Show me pics of your spark plug wire looms
Old Sep 23, 2002 | 04:43 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've got some el-cheapo chrome wire looms that run horizontally alongside my valve covers. They're half broken, and I cut the **** out of my hands every time I have to change my plugs. I want a different set. I've had my eye on the vertical set from Made4U Products, but I don't know how well they would work with a small block valve cover that only has 2 bolts.
Anybody have any suggestions? I'd really like a vertical kit like this one instead of the usual horizontal kit, although I suppose it may be possible to bend the tabs on the horizontal style and make them vertical.
Old Sep 23, 2002 | 11:21 PM
89Irocz23's Avatar
I have the cheap ones on mine too but this is what I have.
Attached Thumbnails Show me pics of your spark plug wire looms-26f02-8-27-16
Old Sep 24, 2002 | 07:37 AM
Jim85IROC's Avatar
I've got perimiter-bolt covers, not centerbolt, but thanks just the same.
Old Sep 24, 2002 | 12:26 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I don't suggest the made-for-yous on perimiter bolt covers. You need to get one that's one piece, otherwise the two bolts do a crappy job of holding it in place.
I have the made-for-yous on my centerbolts and love them. Maybe you should just get centerbolt heads.
Old Sep 24, 2002 | 12:34 PM
Jim85IROC's Avatar
Then I'd have to settle for ugly valve covers.
I wonder if I can take a set of the 1-piece jobs like I've got now, but bend the tabs and swap sides so that they sit up in a vertical fashion. I suppose if the tabs weren't strong enough, I could always make some stronger ones. Just what I need, more customization projects.
Old Sep 24, 2002 | 12:36 PM
99Hawk120's Avatar
Ouch, that was a low blow!
I'd try bending the tabs. You could buy the mad for you set and whip up a custom bracket to attach it to.
Old Sep 24, 2002 | 03:27 PM
86Z28350's Avatar
Have you checked the wire Loom sets in Summit Racing or in the Jeg's catalogs? They have a couple different styles you can use for those perimeter style valve covers. I have a set similar to the pic and they work well and give good clearance.
Attached Thumbnails Show me pics of your spark plug wire looms-wire-loom.jpg
Old Sep 24, 2002 | 09:58 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
These list for about $45 at GM dealers but I got them off Ebay for 10.50... and they looked new!
Old Sep 25, 2002 | 07:16 AM
Jim85IROC's Avatar
Those are what I've got now and I cut the **** out of my hands when I change my plugs. Instead of the horizontal style like those, I want vertical ones that hug the valve covers. Like I mentioned above, I might try bending the tabs up and reversing sides to see what I get.
Old Sep 25, 2002 | 09:57 AM
laiky's Avatar
Hey SMasterson,
Is that a TPIS Miniram???
Old Sep 25, 2002 | 01:23 PM
Jim85IROC's Avatar
Originally posted by laiky
Hey SMasterson,
It's the Holley Stealth Ram. Look on the TPI board for all the info you'll ever want or need.
Old Sep 25, 2002 | 03:13 PM
laiky's Avatar
how does it run? can you pass emmissions?
Old Sep 25, 2002 | 03:41 PM
Jim85IROC's Avatar
Check the TPI board! It's been hashed out 2,000 times over there.
It doesn't have EGR, but there's no reason that it can't burn as clean as any other MPFI system, so it depends on the smog ***** in your area.
Old Sep 25, 2002 | 04:17 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
there ya go, friend.
vertical made 4 you wire looms on perimiter-bolt heads.
The set comes with a 2-hole, a 3-hole, and a 4-hole separator for each side, as well as two 4-hole wire separators without a stud.
I just used a 2-hole and a 4-hole on the valve covers, and a 4-hole farther up for neatness.
Attached Thumbnails Show me pics of your spark plug wire looms-made-you-wire-looms
Old Sep 25, 2002 | 04:19 PM
Car: 82 Trans am
other side
Old Sep 25, 2002 | 04:21 PM
Car: 82 Trans am
SMasterson,
i was just comparing our pics, and it seems that yours is lacking the rat's nest of wiring mine has. Are you using the stock ecm to run your SR, or Holley's computer? also, what else did you remove?
Old Sep 25, 2002 | 05:28 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Here's what I did
Old Sep 25, 2002 | 06:36 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
Those look really nice, I need to get me a set. I just have the little plastic ones that come in the box with the wires. Please don't laugh at me. It runs good
Attached Thumbnails Show me pics of your spark plug wire looms-engine-shot-1.jpg
Old Sep 25, 2002 | 11:26 PM
Car: 82 Trans am
damn 88 427, thats one clean BBC install
Old Sep 26, 2002 | 08:05 AM
Jim85IROC's Avatar
Thanks slickrock55. That looks good! 88 427 Camaro, I got a red x. Your webhost must be blocked here at work. I'll take a look tonight.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
