tachometer
Old Sep 26, 2002 | 03:25 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
tachometer
hey, i hear its helpful to adjust ur idle speed if u have a "real" tachometer....but how do u hook it up? how much do these cost? is it really worth it cuz i know the dashboard ones arent accurate for measurements, thanks
Old Sep 26, 2002 | 04:12 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm confused by your question... But, yes, the stock tachs are known to be not accurate. I was given a 5" Autogauge Tach with shiftlite, retails for $100 in Summit. You can hook it up anywhere, and basically you hook up wires for the power and the other wires go to the distributor.
Old Sep 26, 2002 | 04:27 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
i never really thought about mounting a new tachometer, thats actually helpful...sorry i wasnt clear...i mean like hooking up a tach to measure adjustments, etc...like when adjusting idle speed u can look at something under the hood...i dunno, thanks
Old Sep 26, 2002 | 05:25 PM
Car: 99 Formula
Axle/Gears: 342
Oh, I see now. I'm sure they sell some kind of tool for that, basically same idea, just hook it up to the distributor where the factory tach is for the tuning purposes, then undo it.
Old Sep 26, 2002 | 05:40 PM
camarokev400's Avatar
yeah i love my aftermarket autometer tach.... i dont know about the stock gauges being off.. i just like the looks of the big 5 inch tach with shift light. Installation is easy i think there was 4 wires, one was the green wire that goes to the distributer, black was ground, white was key switch, and blue was power up when you turn your lights on.
Old Oct 21, 2002 | 06:50 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
The wiring on my car is a mess, Where do I hook up the wire for the distributor I don't see a clip on it like most other cars I've worked on.
Old Dec 16, 2002 | 11:11 PM
quicklil87lt's Avatar
i just looked at all the small wires coming out of the distributor. you gotta find the white wire. mine were real dirty so i cleaned them off and when i got the white one i spliced the green wire from my sun pro 5 " tach into it and ran the power and ground wires. works great and also made me realize howw much off the stock tach was
Old Dec 16, 2002 | 11:33 PM
TBI305Camaro's Avatar
how far off is the stock tach? I think mines off because it hardly stays running with a 500rpm idle...750 idles fine tho.
I like the gauge pod on the pillar. I want to do that soon with a new oil pressure gauge and tranny fluid temp.
BTW what guages are those inplace of the old ones?? I like the looks of them. and how hard was it to install?
Old Dec 17, 2002 | 08:18 AM
felo72's Avatar
I think this might answer your question, the tool you're looking for is called an engine analyzer. You hook one wire to the distributor (where the tach wire is now), and hook two cables to the positive and negative posts of your battery. You can get these at any parts store, and they read RPM accurately.
Old Oct 19, 2004 | 02:01 PM
about2break1128's Avatar
Car: 84 Z28
Engine: 305 HO
i have a Q...i dont have a factory tach...but want to add an aftermarket one...where would i hook it up at?
Old Oct 19, 2004 | 03:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The two tachs I've installed both had a ground wire, a wire to the coil, and a few others, but those were the two important ones. They were installed on old points distributors though, dunno how they'd hook up to an HEI.
Old Oct 19, 2004 | 04:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Ground wire to a good chassis ground. Power wire to an ignition switched source (probably something available in the fusebox). Tach wire to the Tach terminal on the distributor (it's marked).
toones
Jan 6, 2016 06:00 PM
ChevyZ71
Aug 13, 2015 07:30 AM
99Hawk120
Mar 13, 2002 02:24 PM
