Largest tires on stock rims?
Old Sep 26, 2002 | 04:44 PM
MrNova's Avatar
Whats the biggest size tire's I can fit on stock rims? Right now I've got 245/50/16.
Old Sep 26, 2002 | 04:57 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
16x8 stock wheels?
Got 255-50ZR16's on mine (rear)
I don't think they recommend any bigger on 16x8
-Rich-
Old Sep 26, 2002 | 05:15 PM
MrNova's Avatar
Whats the differnece between 245's and 255's? Im thinking of buying a set of new Khumo 712's, because my car is just going nuts in the rain.
Old Sep 26, 2002 | 05:17 PM
Car: 92 Camaro RS
255 is 10mm wider.
-Rich-
Old Sep 26, 2002 | 05:22 PM
MrNova's Avatar
No I mean what will this do to the performence and handling?
Will going to 255's mean I'll get wheel rub or something negative?
Old Sep 30, 2002 | 09:07 AM
Car: 92 Camaro RS
There's plenty of room with 255's, even at 2" lower than stock, but the tire manufacturers don't recommend going any wider on an 8" wide rim. I have no rubbing problems.
A few guys have ZR-1 size 17x11" on the rear with 305's and as long as the back spacing is correct they don't rub.
As far as performance goes (with tires) bigger is generally better, as long as it fits without rubbing.
-Rich-
Old Sep 30, 2002 | 09:08 AM
Car: 92 Camaro RS
oops
Old Sep 30, 2002 | 09:57 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
My black 86 IROC had 295/50-16's on the back when I bought it. They rub a little when pushing through a curve (you know, when you're not satisfied with just slowly pulling away from the guy that's been tailgating you and you want to just disappear!!). Anyway, they are a little too big, but everyone like's the way they look. I've had folks follow me down the road till I stop (make's you nervous) then pull up and ask about the tires. Makes it worth it.
Old Sep 30, 2002 | 11:16 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
I believe the stock rims for my '83 TA are 15-7's. The stock tires are 215/75/15. I put yokahama 225/60/15 V-rated tires on the front, I like them a lot, but want some wide *** one's on the back. Anyone know what the biggest you can go on a 15-7 is?? Lookin to get new tires in about a week or so (Inspection ends tonight...damn).
Old Sep 30, 2002 | 11:54 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i'm running 245/60/15 goodyear eagles on 15x7 wheels on all four corners on my 84 camaro.
i rub up front, but have plenty of room out back.
i wouldn't go bigger than a 245 on a 15x7 rim.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Randomtask2
Aug 13, 2015 01:57 AM
Exxon Limited
Aug 9, 2015 08:13 PM
