help TGO! I cant get headers to stop glowing....
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
nevermind this thread..please let it die
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
yep
sounds like a lean condition........
kinda like n2o when it runs lean, it's like a blow torch in the combustion chamber........
i'll bet ed will find it....
It could be a rich or lean condition. I had the same problem and I was actually too rich, once I leaned it out with a afpr, I haven't had the problem since. If you think it's rich, find out to be sure, put a fp gauge on it and find out. We could tell you all day long it could be rich or lean, but you have to tell us your scenerio.
The simple fix is just to throw a afpr on it and adjust it to the right fp you need.
19 pounders came stock with 3.4 v6's...
I'd say the 30lbers are fine, Pressure should be in the 48-50PSI range with no vacuum on the FPR... after that, let ed fool with it.... your FP might be too low, causing the injectors to fire like crap...
just my stab in the dark.
Linson
Sep 21, 2015 01:08 PM
