good at high rpms and bad at low rpms
Old Oct 20, 2002 | 05:39 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Alright this is for a buddy of mine. His 350 SBC with a moderate cam, single plane intake, and pretty good heads(i dont know the specs of them) runs poorly when getting on the gas <2000 RPMS. Above 2000 RPMS while getting on the gas it is smooth and all power. Now I am not talking about a lack of torque, it just runs rough and misses out a little bit. What could the problem be, it has not always done this???
Brady
Old Oct 20, 2002 | 08:43 PM
ttt
Old Oct 21, 2002 | 06:29 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Vacuum leak? Is this car computer controlled? If not, is the vacuum advance hooked up correctly to the distributor?
Old Oct 21, 2002 | 01:57 PM
Dingus's Avatar
I'd check the valve lash. My rockers had loosened up and my car ran like crap at low RPM's but ran strong at higher RPM. I reset the valves and the problem was gone.
Old Oct 21, 2002 | 05:28 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The setup he has is probably not a torque setup. Single plane manifold and good heads, assuming he has big port heads. That would create throttle response problems.
Old Oct 21, 2002 | 10:00 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Just out of curiosity, what are his cam specs? (spec. lobe separation) He could have built a completely top end engine without any low end driveability... Single plane manifolds are not recommended for daily driven vehicles since the power band (with matched cam) usually lifts to about 2000-6500 RPM up from about 500-5500.
Old Oct 21, 2002 | 10:15 PM
i dont know - he might not even now. it is not a lack of torque, it is missing out and running rough. it didnt always do this just started
Old Oct 22, 2002 | 12:00 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Well, if you saw my head gasket post... I thought I had blown a head gasket, but it turned out to be the timing chain, the car idled very lopey and it stalled when I shifted sometimes, or just while idling... the top end was fine, just a VERY crappy idle.
How old is the engine is one question... if over about 80k miles it is possible that the timing chain could be too stretched, although most chains last a lot longer (158k for me).
You don't want that baby to break though, that's a fast track to a nice boat anchor.
I would suggest testing the compression (two low cylinders may be a blown head gasket) look at the oil for discoloration (grey and foamy is probably a head gasket) and check the valves for leaks, broken springs and bent valves... If you hear a clackity clackity from the timing chain cover than yank that thing ASAP.
Old Oct 22, 2002 | 01:32 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
I'd start by pulling the spark plugs to see whats going on in each cylinder. If it's carbed it may be just running rich or a fouled plug which cleans up with a good rev. Look at the easy stuff first, spark plugs, carb tuning, basic tune up stuff.
Old Oct 25, 2002 | 08:52 AM
nlurch80's Avatar
i was having that same problem with my 1987 Z28 305 and it turned out to be the furl pump and regulator. so look at that.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
customblackbird
Aug 15, 2021 10:16 PM
jklein337
Sep 19, 2018 06:23 PM
Fronzizzle
Aug 19, 2015 01:36 PM
jackhammer
Aug 15, 2015 10:04 PM
