Crack this nut....freaking car......
Old Oct 29, 2002 | 02:56 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
The guys over at z28.com told me to come here for some help....so here is my problem.....look in the sig for my mods.........why am I running 8.8@81mph in the 1/8 mile? I have yet to break out of the 13's.....13.2@108mph is the cars best.
.....the times above are before adding 4.10's....alum DS, Flywheel, LCA's, and Nittos.......when I added this stuff it didn't get any faster. Granted I have not run the car in the 1/4 yet but I have ran it in the 1/8 and there was no improvment in ET or MPH. HELP! I know Traxxion has a car similar to mine....I'd like to know his secret or if any of you could help that would be GREAT!
BTW in this months issue of GMHTP they said with a carb their 396 powered F-bird made 481hp...with the FI (superram) it made 290!!!!! ..........mabe a carb is the way to go.....
POS350Z
Old Oct 29, 2002 | 03:01 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
HOLLY *****.....look the FNG posted in the wrong section.....can this be moved to the Tech/General engine???
WETAWDED.....POS350Z
Old Oct 30, 2002 | 07:59 AM
leirch's Avatar
What are your 60's?
Alot of your problem could be tuning issues also.
Old Oct 30, 2002 | 10:59 AM
ede's Avatar
ede
welcome and yes it can be moved
Old Oct 30, 2002 | 11:51 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Originally posted by leirch
What are your 60's?
I was thinkin the same, he has DRs though.
Old Oct 30, 2002 | 06:56 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
....my 60's are around 2.0......what kind of tire pressure do you guys run on the Nittos? I either bog the motor or spin like crazy (grabby spec clutch)......
Thanks POS350Z
Old Oct 30, 2002 | 08:11 PM
rezinn's Avatar
108mph should be good for high 12s. 13.2 isn't really bad for that mph. How are the track conditions? A lower 60' will definitely help.
edit: didn't read your sig
Old Oct 30, 2002 | 08:55 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
if u need to bust a nut youre on the wrong website.
Old Nov 1, 2002 | 12:16 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
.....hmmmmmm.....any ideas? I'm starting to think its the 'puter....do I need a DFI? How are some of you guys running 12's??
POS350Z
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
86IROC112
Nov 7, 2015 06:50 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
