roller rockers on vortec heads
Old Oct 29, 2002 | 04:20 PM
atomicm0nk's Avatar
I have vortec heads and i am looking into roller rockers for them, but since the valvecovers are centerbolt, only some rockers will work and they are twice as much as standard rockers. My question is if i get the centerbolt to standard bolt conversion for the valvecovers, will any rockers fit? I can do this for 40 bucks because a friend of mine recently bought a conversion kit for 140 but dosnt want it anymore, so it would still be cheaper than running out and buying 300$ rockers.....
Any ideas suggestions or experience will be greatly appreciated
Old Oct 29, 2002 | 04:42 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Why do you want to spend money on valve covers adapters
and then buy cheap roller rockers.
Why not just buy some good rockers that fit the centerbolt heads
like Comp cams pro magnum or magnum rockers
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
TRD sells hi profile valve covers for centerbolt for $100. Thats what I'm running. I'm running 1.5 comp roller rockers, but I also have screw in studs and guide plates so I have the "cheaper" non guided rockers. I'd say go with aftermarket centerbolts and cheaper roller rockers, because running adapters on centerbolt heads cancels out the whole reason centerbolt covers are better.........less leaking!
Old Oct 29, 2002 | 09:56 PM
atomicm0nk's Avatar
no sorry i explained it wrong, and i didnt add enough info... its not the fact that i want "cheaper" roller rockers, im intending on getting crane rockers because i havnt heard anything bad about them, and i need the 1.6 ratio, but the rockers for the non centerbolt are 190$ and the ones for centerbol (that i can find) are 300$ new. maybe im just looking in the wrong places, or i just skipped a page in my summit. And spending 40 bucks on adapters beats spending an extra 110 on rockers....
Old Oct 30, 2002 | 04:46 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I'm running Crane Blazer aluminum roller rockers under stock center bolts covers with no problem. $161.99
Old Oct 30, 2002 | 06:24 AM
ede's Avatar
ede
buy some steel rockers from comp, 1318s, lighter and stronger than aluminum, and they don't fatigue.
Old Oct 30, 2002 | 10:17 AM
atomicm0nk's Avatar
whare do you get the crane blazer rockers, i cant seem to find them
Old Oct 30, 2002 | 10:25 AM
83 MidniteZ's Avatar
I would go ahead and get the rockers made for centerbolt heads. When I was building my motor, i used the adapter and bought a set of Crane Energizer 1.6s which didn't fit! Because they are wider than the centerbolt rocker arms. I ended up running the comp magnums...
And as for that adapter, it worked for a week, then the o-ring seal broke and it left me stranded on the side of teh road with a waterfall of oil running over the side of my heads onto my headers which wasn't too pleasant.
Old Oct 30, 2002 | 02:30 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Here is what you need!!! CHeaper price and good item. I plan on finding a set for my TPI when the time comes. They look like the harland sharp
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?
ViewItem&item=1871369840&rd=1
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
