Lower comp. needed, new heads?
Old Nov 11, 2002 | 08:49 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi...
I think I'm going to blow my engine when I put on my 9 psi kit. So I'm thinking of replacing my 65 cc canfield heads with some 74 cc heads, any recommendations?
And what about to go for 220 cc heads? would it be a overkill?
/N.
Old Nov 11, 2002 | 09:01 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I may be wrong, but I believe there are some guys on the Power Adder board that run only that much psi with compression above 9:1 or so.
I wouldnt' go with 220cc heads, unless you plan on revving that motor above 6500rpms, which that much cc will kill your low end. Also, unless you have like at least probably a 383, if not a 400ci motor.
Old Nov 11, 2002 | 09:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What kind of pistons are in it? (flat top, dished, etc.)
Old Nov 12, 2002 | 12:10 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Wiseco flat top.......
Old Nov 12, 2002 | 02:53 PM
Guest
Guest
Posts: n/a
Why not change the pistons instead?
Old Nov 13, 2002 | 12:04 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
more job..............but maybe its the right thing to do?
Old Nov 13, 2002 | 12:09 AM
Car: 99 Formula
Axle/Gears: 342
I would think cheaper too.
but definately, more work.
Old Nov 13, 2002 | 12:19 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Y not intercool your blown hi compression motor.
You make more pwer and save money replaceing pistons and heads.
All serious powered supercharged motors are intercooled.
Old Nov 13, 2002 | 12:21 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
If you read my sign. You'll see that its going to be intercooled........
Old Nov 13, 2002 | 12:27 AM
Car: 99 Formula
Axle/Gears: 342
How much boost do you plan on running?
Old Nov 13, 2002 | 12:33 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
9 psi, I think I have 10,4:1 now in comp. I'll have to talk to my engine builder to be sure. I know LT1 have 10.5:1 and run 6-9 psi so I'll probably be fine with my setup..........
Old Nov 13, 2002 | 01:04 AM
F-BIRD'88's Avatar
You can easily lower the cr of your motor as much as nessessary by shaping and de shrouding the combustion chambers of your present heads. There is loads of meat there to do this. You'll pick up some flow too.
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
