My Alternator
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
My Alternator
MY GUAGE SAYS THAT I MUST BE LOSING POWER SINCE I HAVE TO CHARGE IT 18 OR THE GUAGE SAYS THAT AT LEAST INSIDE MY CAR IT SHOWS 18 ON THE AMPS. WHATS WRONG
Car: DAF
Engine: 3 cyl 2 cycle
Transmission: variable speed
if you r trying to read the stock voltmeter it might not b accurate....many factory guages are not.
first thing to do is to check the voltage at charging rpm WITH a good readable/acurate voltmeter and comfirm the numbers.
With a battery that is good and charged...no more than 16 volts....nominally 14.5 -15 with no acessories running.
If it shows 18 amps, you need a new alternator. It should put out close to 100 amps. I think you mean volts though, if so it's actually overcharging. You need to measure the voltage at the alt and battery and see what's really going on. If you're getting 18 to the battery, you're going to need a new alternator before you kill the battery(and other things).
alternator
if the gauge in the car is reading 18 volts you are "overcharging" meaning..bad volt regulator. now if you are reading 18 amps off of the alternator itself it is getting ready to take the big dirt nap. Time to get a new alternator.
i dont really drive my camaro that much maybe 4times a month. but now that im starting to drive it more im starting to notice these things. so i will drive it i guess for another week or so and tehn see waht happens
Car: 4
Engine: 6
Transmission: 5
Black wire of the meter to ground (engine block unpainted surface), red wire to the big terminal on the back of the alt.
Should read mid-12s with the car turned off, 14.2-14.5 with the car running.
Rule #1 ... NEVER EVER TRUST FACTORY GUAGES!!!
My ranger read 10 volts when it was acutally 14.
my sister .... "My car wont start" (99 eclipse)
me ... "you have gas in it"
sister .. "gauge says 1/4 tank"
I put about 1/2 gallon of gas in and it starts.
RB83L69 is right, its trim package. They why some cars had the option for a tach and guages instead of idiot lights. Stop drivng that car around before you test it with a good radio shack volt meter. Borrow someones if you have too, heck .. my old mechanic would take 3 min of his time and put a meter on it for free.
raymondandretti
Sep 27, 2015 06:43 PM
