roller lifter question
Old Nov 20, 2002 | 03:47 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
When I removed my lifters I put them all in baggies with there location marked on the baggie so that they would be installed where they came out.One thing I did not pay attention to,until I had them all out ,was this small oil passage.Does it have to be facing the way it came out?,and if so does anyone know wich dirrection this is?It can only be one of two different ways beacause of the fact that the lifters dont turn when installed.Maybe it don't even matter,I don't know.Thanks for any help!
Old Nov 20, 2002 | 03:50 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Sorry about the picture size,I thought I downsized it enough.Well at least it's clear as to what I'm talking about.
Old Nov 20, 2002 | 04:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Doesn't matter, as long as the lifter engages the spider properly.
Old Nov 21, 2002 | 02:59 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Thanks for the reply.I didn't figure it mattered much since no one mentions this when discussing roller cam swaps.I am going to use the assembly lube for the cam that came with it,with the lifters,do I just dip them in some oil before I put them in?
Old Nov 21, 2002 | 06:27 AM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
I heard you're NOT supposed to use assembly lube with roller cam engines, just oil. Maybe this only has to do with applications using the LT1 cams, I don't know. Better look into it though.
Old Nov 21, 2002 | 10:31 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I used lube on my roller cam for added protection. 5,000 miles later still good
Old Nov 21, 2002 | 10:48 AM
TBI305Camaro's Avatar
id like to get some more info on that since I will be doing a cam swap soon in my motor and its roller....
Its ok to reuse roller lifters right?
Old Nov 21, 2002 | 10:49 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
yup
Old Nov 21, 2002 | 02:17 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
A bottle of lube came in the box with my roller cam.I don't know if it's the same thing as assembly lube,but it is definitley to be used when installing the cam.It stays on the cam as oil will run off.
Old Nov 21, 2002 | 07:56 PM
CamaroDriver's Avatar
It's probably smart to use the lube on the journals that ride the cam bearings.
It won't hurt to put it on the lobes. It would only help, or do nothing.
Another place to use it is in the lifter bores. It takes a little while for the oil pump to get oil in that area.
Old Nov 30, 2002 | 11:30 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
It does say in the instructions that came with my roller cam to not use assembly lube.The bottle of lube that came with it is to be poured in with the oil.I just soaked mine with oil like it said,and put some assembly lube on the distributor gear, per the instructions.
Old Nov 30, 2002 | 11:41 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
I just got a hyd. roller for the race car, from comp cams. There was no assembly lube with it. All the flat tappet cams,I have bought came with it.
beastin91rs
Oct 9, 2015 07:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
