Whats the easiest way to press out the wrist pins?
Old Nov 24, 2002 | 11:30 AM
Nasty_Bird_'90's Avatar
I just messed up a connecting rod with a little bit too much heat trying to press out the stock wrist pins. Before I mess anything else up, I figured I'd find out how you guys are doing it. I was holding the piston in a vise and heating up the rod with a torch. When it started to get hot, I would press the pin out with the vise. It takes quite a bit of heat to do it this way, and I think that's why the rod got tweaked. BTW, it's an L98.
Old Nov 24, 2002 | 12:54 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Bad idea..you are about to destroy your rods..let a machine shop handle this.
Old Nov 24, 2002 | 12:57 PM
Guest
Guest
Posts: n/a
Why dont you take them to someone with the proper tools and have them do it? It'll save alot of time, headache, and rods.
Old Nov 24, 2002 | 02:34 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
we did it with a hydraulic press and no heat. worked fine for us. but, if you wanted to be on the safe side, let a machine shop do it.
Old Nov 24, 2002 | 03:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You press them out cold with a hydraulic press.
You install them by heating the con rods. When heated up enough, the end of the con rod will turn blue.
Old Nov 24, 2002 | 07:49 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
i meant we pressed them in with a hydraulic press and no heat. and, if we needed to take them out, thats what we wouldve done too
Old Nov 24, 2002 | 08:42 PM
Steve86TA's Avatar
Car: To many to list
Man,take those to the machine shop before you destroy them.I dont think you are supposed to put heat like that on rods anyway.
Old Nov 24, 2002 | 09:50 PM
radiateu2's Avatar
wrist pin removal
My machine shop removed the pins from old pistons cold without breaking anything he did have a special tool that took up the extra space between the rod and piston. The tool actually cost 1500 dollars. They preesed the pistons using heat on the rods only.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
InfernalVortex
Apr 20, 2021 11:31 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
88CamZ
Oct 8, 2015 10:29 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
