How well would powder coating hold on a valve cover?
Car: '87 Z
Engine: 355 in the works
I'm thinking about messing with my old valve covers and having them powder coated. How well would powder coating hold up on them? And what is a good way to get the buildup off of them? Thanks.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Powder coat holds up well on everything except exhaust. It's baked on at 400* so anything that gets hotter than that will melt the powder coat.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
holds up real well. here's mine. the only thing i found that will attack powder coating is carb spray. powder coating is ground up plastic melted onto whatever you are coating at 400*
Car: 91 camaro
Engine: 383
To get all the crust and disgust off your valve covers before painting them, a couple cans of carb cleaner should do the trick. You may not need to get them super clean though. Everytime I have taken something in to get it powdercoated, the powdercoating place will bead blast it to remove all the old paint and dirt.
Car: '87 Z
So will anyplace that powdercoats clean it up? The place here is a honda speed shop, and all I've heard is it's 40$ for anything the size of a 16 inch wheel. I haven't talked to them or anything yet, but that's what I heard. I guess i'll call them and ask them about it, get some more info on it...
NBrehm
Aug 25, 2015 11:49 PM
