Help Removing Emissions Stuff...
Old Dec 1, 2002 | 04:39 PM
Johnny Camaro's Avatar
I was just out under the hood of my '91 RS L03. I was digging around cleaning and what not and noticed that there is just way too much crap under the hood. I would like to remove all of the pollution control junk and toss it but before I do that I wanted to ask a couple of simple questions.
1. What if any benifits, if any, will I see from removing all that stuff?
2. Is there any worries with the computer throwing codes after the removal?
3. Has anyone done this that can give me a brief tutorial so that I can be thorough?
Old Dec 1, 2002 | 10:47 PM
darbleinad's Avatar
Car: 84 Trans Am
first of all do you have emissions tesing in your area. i am gonna assume you dont or you know someone who can get you through...or else you wouldnt be asking this.
now i am not the best person to answer this because i dont know much about fuel injected cars.
however one benefit is obviously gonna be a cleaner, less clutted engine bay and it will be easier to work on the car.
i removed every piece of emissions equipment on my car excpet the PCV valve, you need this to properly vent you engine...so leave it on. you can put a breather on the other valve cover intead of the tube and filter than run from the air cleaner to the valve cover
hopefully someone else that knows tbi cars and will respond and help you out.
Old Dec 2, 2002 | 11:58 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Re: Help Removing Emissions Stuff...
One possibility occurs to me:
If you remove the air pump, and I assume you have one, I would think that removing the air pump would change the oxygen content of the exhaust passing over the 02 sensor. After all, the pump is pushing air into the exhaust manifolds, burning up some of the leftover combustion products in the exhaust. If you take the added air out of the picture, what happens?
Now perhaps the change is small enough that the computer merely compensates for it slightly when cruising...
I suppose the bottom line is remove pieces one at a time and keep records of what you pulled from there. I would be worried about the driveability or gas mileage suffering from this particular modification.
Old Dec 3, 2002 | 07:41 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
As far as I know the air pump is only pushing air into the manifolds until the engine is hot. then the air is diverted to the cat instead. and the ECM ignores the O2 sensor readings until the engine is hot anyways.
Old Dec 3, 2002 | 11:20 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Hmmmm, if that's the case then pulling the air pump shouldn't affect the driveability at all then, just increase emissions during warmup.
And the air that is pumped into the cat, that's what the half-inch tube running down to the exhaust is about?
I've heard that the air pumps don't really rob that much power off the crank so they're hardly worth removing in that sense but I agree they're ugly mothers, usually built cheaply and getting rid of them sure cleans up (alnd lightens up) the engine bay.
I pulled all the emissions hardware out of a '77 Toyota and it came to about 35 pounds! The air pump, brackets, hoses, the array of vacuum devices made for a huge pile on the floor.
Old Dec 3, 2002 | 11:26 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I've removed my A.I.R. and have not gotten any codes or noticed any difference in driveability.
Old Jul 12, 2009 | 12:10 PM
91-rs-305's Avatar
Car: 1991 rs camaro
Engine: 305 TBI
Transmission: A4 with automatic overdrive
removing emissions items like your air pump will clean up your engine bay and free up a little bit of horse power cause your engine is not always turning the air pump.it will not thow any trouble codes but make sure when you remove those lines from the exhaust manifold that you plug them with pipe plugs or else you will have a major exhaust leak and there could be detonation in the pipes.
good luck
Old Jul 12, 2009 | 03:56 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
This is a very common topic, and I think there is even a thread in the TBI forum about it for your specific engine.
Just remember its VERY illegal, even if your area doesnt do emissions testing. Its a federal law, and its just a matter of time before the current government makes every state and city do emissions testing in the name of "global warming."
We here in SoCal have several cars that make over 400 horsepower, get 20+ miles per gallon, and pass CA's tough emissions test with flying colors. Its not difficult.
Old Jul 12, 2009 | 04:21 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
this is almost 7 years old
Old Jul 13, 2009 | 07:47 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I would keep all the stuff you pulled off in case you get emissions testing in your area.
Old Jul 14, 2009 | 02:40 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
I removed all the smog stuff from my car and its not throwing any codes or anything and its running just fine
Old Jul 14, 2009 | 03:10 PM
Are you getting better performance and milage?
Old Jul 14, 2009 | 03:45 PM
Car: 1988 camaro
Engine: cammed 3.1
When i removed it i also added a new distributor, coil, and open element air filter so im not really sure
Old Jul 14, 2009 | 04:13 PM
Hey man, you wanna race me man? With those 373's you will do good. Do you have that hood ventilated?
Old Jul 14, 2009 | 04:23 PM
Car: 1988 camaro
Engine: cammed 3.1
Lol man my car isnt even registered yet im still working on it yeah the hood is ventilated soon im getting hooker 2460 headers a magnaflow high flow cat , and either a mac performance cat back or a magnaflow the weird thing is its sounds pretty good with the stock set up
Old Jul 14, 2009 | 04:39 PM
Is that a stock muffler you have on it?
Old Jul 14, 2009 | 08:15 PM
Car: 1988 camaro
Engine: cammed 3.1
[quote=Stevolwevol;4220291]Is that a stock muffler you have on it?[/quote
yeah its stock with 3 inch tail pipes welded on
Old Jul 14, 2009 | 08:34 PM
I have 3 inchers on my rs also. They are stainless, w/balognie sliced. I have a flowmaster behind em.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
