Blinkers don't work???.......HELP
Old Dec 14, 2002 | 09:13 PM
FLYNLOW92rs's Avatar
OK, my blinkers light up....
They blink when i put on the hazards/flashers.....
BUT when i press the lever up or down, they just light up and stay on??
WTF is going on here?? Any ideas, on what to fix or what went wrong.....
HLEP...
Old Dec 14, 2002 | 09:50 PM
82camaro's Avatar
Car: 82 camaro SC
Hazards usually run off of a different flasher than the blinkers. Could be the flasher, burned out bulbs, wrong bulb size, bad wire. Turn on the blinker and see what lights on the outside of the car light up. What have you done to the car recently--if anything? In my experience, if both left and right blinkers stop working at the same time, it's usually the flasher.
Old Dec 14, 2002 | 11:12 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
it's your flasher unit, the turn signal one is seperate from the hazards one. before you buy a new one, you can verify it by swapping the two flashers to see if that fixes the problem
Old Dec 15, 2002 | 12:21 PM
NTChrist's Avatar
Try the flashers too, but I think that's what my car did when it burned out a signal light. Make sure all the lights are coming on first. Easier to just walk around the car, rather than start messing with flashers!
Of course..... It could be that you're low on fluid! Try Kaleco for some more!
Old Dec 15, 2002 | 05:44 PM
ALL the lights that come on when you turn on the signal, they still work...
No burnt out bulb here.......So where is this "flasher" unit you guys are talking about??
Old Dec 15, 2002 | 06:01 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
hmm never actually replaced 1 but im pretty sure its one of the happy lil boxes in the junction box above all the fuseamagigs.. sorry to get all techinical on ya.
Old Dec 15, 2002 | 09:00 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
mine are on a black box thing under the drivers side dash. took off the panel and its on the right side under the steering wheel. gotta drop the box then youll see both the flashers.
Old Dec 18, 2002 | 09:48 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
it's the blinker fluid
you guys really need to learn about your cars
Old Dec 18, 2002 | 09:59 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
check your hose if the fluid is ok, they get pinched when you turn too sharp
Old Dec 18, 2002 | 10:10 PM
Oh yeah...
Where do i go about finding this so called blinker fluid....
Is there a resevoir anywhere on the interior??
Maybe their are air-pockets in the return feed line......
Old Dec 19, 2002 | 06:28 PM
LYV18F's Avatar
the flasher is right by the fuses under the steering column. it's a real PITA to get to because you have to be looking up with half your body out the front door. but once you find it it's a matter of popping out the old one and putting in the new one. i think the part costs like 2 or 3 dollars.
Old Dec 19, 2002 | 07:36 PM
Firebird SE 84's Avatar
the blinker fluid resevor is right beside the spare muffler bearings and its all under the dry water tank
c-ya
Old Dec 19, 2002 | 09:56 PM
82camaro's Avatar
Car: 82 camaro SC
Just to throw something else out there: The wrong size bulb can do this. For example if you installed 1157's where 2057's should be--the 1157 bulbs don't pull as much power and can prevent a current based flasher from flashing. But if you haven't messed with the bulbs recently, that's probably not it.
Old Dec 20, 2002 | 03:32 AM
JoeJuggalo's Avatar
Car: 1984 Z28/ 1990 Plymouth Laser RS-Turbo
Engine: 1977 Chevy 350
Transmission: 5-speed
I have the same problem but this is quite funny. Whenever my voltage is low(12v) they won't blink, but when it it high (14v) they blink. I'm probably going to get an alternator to fix the problem since whenever I have my heater, defroster, lights, and stereo on; my turn signals won't blink. If anyone knows a better way than for me to buy a better alternator, let em know. I just think it wierd that my car need 14 volts to blink my blinkers.
Old Dec 20, 2002 | 03:41 AM
Car: '87 Camaro LT
Engine: 355 L98
i'd try a new $3 flasher before i spent $40-60 on an alternator, and if that doesn't fix it then you'll have a spare.
Old Dec 20, 2002 | 01:25 PM
JoeJuggalo's Avatar
$3 flasher= $3 bulb? I haven't checked the bulbs to see if they are factory, but I guess I will do it soon, to save me some money. Thanks.
Old Dec 20, 2002 | 04:47 PM
Car: '87 Camaro LT
Engine: 355 L98
by $3 flasher i mean the little silver cylinder under the dash, not the bulb. i doubt after all these years you'll still have factory bulbs.
Old Dec 22, 2002 | 06:45 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
mines doing something like that,when i try to make it blink it stays on.but i got nailed hard on the front drivers side. i replaced all the bulbs, so when my running lights are on its all good,then after a little while my right front running light goes out and the left blinker thing on the inside of the car stays on. and i checked all the lights from the outside and the left rear blinker wont work at all,even when the hazzards are on, and i replaced the bulb a few times and it still wont work. what the hell is wrong w/ it???
Old Mar 25, 2003 | 11:23 AM
Well more problems people.....The blinkers magically started working again, but then, they broke again....
Now when i turn the lever, the Lights don't even light up, the green arrows on the dash don't even light up...
What could be the problem...
Help...
1992rs/ss
Jan 31, 2025 05:10 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
dhonda200
Aug 11, 2015 11:50 PM
Fronzizzle
Aug 9, 2015 01:15 PM
