Oil Pressure Guage Help
Old Dec 24, 2002 | 11:10 PM
92RSMuscle's Avatar
well, i got an oil pressure guage...i have a 92 camaro, the guage i have has a tube coming out of it (Mechanical guage?) and im wondering, how do i install it? it came with two fittings and it says it has to go into the "Pressure Port"....where is that? since i have an electrical oil pressure guage (stock) now, might there be a sensor in there? if i take out the sensor and swap it for the mechanical one, would i get a trouble code?
please help me!!!!!
i have a 3.1L
Old Dec 24, 2002 | 11:15 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
Re: Oil Pressure Guage Help
please help me!!!!!
i have a 3.1L
the oil pressure sending unit is right next to the oil filter
no you will not get a code
Old Dec 24, 2002 | 11:34 PM
92RSMuscle's Avatar
can i leave it just sitting there?
Old Dec 24, 2002 | 11:46 PM
i guess i should ask, why do you want another one?
dont forget that your oil pressure swith also doubles as your fuel pump relay when your actual fuel pump relay bites the dust
IMHO, i'd keep the stock one, if its not broke dont fix it, and if it is broke, fix it with the correct replacement
Old Dec 25, 2002 | 06:14 AM
ede's Avatar
ede
unless gm changed the sender above te oil filter is for the fuel pump and the gauge sender is on the china wall near the distributor. remove the sender on the china wall and run the mechanical gauge from there. if there is no sender in the china wall there should be a plug, so remove it and run the mechanical gauge from there. i'd trash the plastic tube and run copper.
Old Dec 25, 2002 | 07:49 AM
i think they changed it, i believe the style you are speaking, i have that on my 87 305, on my V6 i just have the sending unit/switch above the oil filter
Old Dec 25, 2002 | 09:38 AM
ede's Avatar
ede
88 is the latest f body i was ever really deep into and it had both senders, china wall and above oil filter.
Old Dec 25, 2002 | 10:22 AM
bradkeith's Avatar
ede, all the v-8's in the 3rd gens have both of the oil pressure ports that you described. However, the 2.8 and 3.1 V-6 have the port above the oil filter.
92RsMuscle, YOU HAVE TO use a T or a three-way splitter on your car. 91 is right, there is the secondary switch for your fuel pump there too, If it sees no oil pressure, no fuel.
By the way as ede mentioned before also use copper tubing. The plastic becomes brittle over time and WILL leak or break, probably while driving. Or can melt.
brad
Old Dec 26, 2002 | 09:28 AM
92RSMuscle's Avatar
well i just bought a 78 Firebird that im refinishing, so i think due to the fact that i can mess so much up, im just gonna put it in there
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
