governor
Old Jan 2, 2003 | 01:23 PM
piskey2002's Avatar
governor
how do i dissable the governor on my iroc. i have a low speedo, only up to 85 mph and it stops, i hae a higher speedo and how do i go about doing the changes and making my car perfom faster. it s atease when you have half the pedal left and you cant go any more, im worried ill break the needle, or what can happen if i do go beyond?
shawn, thanx
Old Jan 3, 2003 | 01:01 AM
racerx004's Avatar
First off lets get a little info on your car.
You say you have a 85 speedo, so I'm guessing that it's about an 85 or 86.
I don't think you have to worry about braeking the needle on the speedo. I used to bury my 84 speedo constantly, and never really had a problem with it.
You have to figure out what kind of speedo you have to swap to a higher speeedo, whether it is cable driven, or electric.
Let us know and we will try to help you out.
Old Jan 3, 2003 | 08:28 AM
ctandc's Avatar
Governor?
A governor ( in the speed control sense ) actually prevents you from going past a preset speed via some means to keep the engine from running....like cutting off fuel or spark etc until the engine gets back below a certain speed.
Just because your speedo reads 85 MPH, does NOT mean you can't go past 85 MPH if you're wallet can stand the ticket
MY 85 IROC w/ a 350 TPI has it's original 85 MPH speedo still. Didn't stop me from pacing a buddy of mine in his newer model TA so I could get an idea of my top speed.....and it didn't hurt the speedo a bit.
I kind of like the 85 mph speedo...that way, when a cop pulls you over for going some insanely high speed, and he asks the inevitable question ( if he doesn't take you into custody... )
" Do you know how fast you were going?!?"
You can honestly answer...my speedometer was reading 85 mph.. :P
HTH
HikoriYami
Sep 21, 2015 07:11 PM
crazynights
Aug 21, 2015 06:53 AM
MikeH
Nov 11, 2001 12:32 PM
EDDIETA_ZZ3
Jul 5, 2001 05:59 AM
92Z
Feb 16, 2001 11:03 PM
