How can you tell if a governor is bad?
Old Nov 8, 2001 | 07:26 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I had my tranny rebuilt recently and the mech put a different governor in and it shifts way to early. I got my original back from him he said if i install it i will have problems. What could be wrong with it? I cleaned it up with brake cleaner and the piston inside seems to be moving back and forth.
90 IROC
SuperRamed 406
Trickflow 23* heads
Old Nov 8, 2001 | 07:52 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
http://www.transonline.com/electroPu...fm?pageID=2176
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
Old Nov 8, 2001 | 07:55 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Check the condition of the weight pins and pin holes for ware. Check the plastic gear.
the shaft should have no wobble at all
the valving inside can get scored and hang up from grit and clutch dust in the trans. The springs can loose tension from heat.
The shaft journals should be perfect with no scoring. A bad governor can affect both full throttle and part throttle up and downshift points. Generally it has nothing to do with whether the trans slips between gears, just the shift timing.
Old Nov 8, 2001 | 08:35 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Thanks guys! IM going to get a new one...The gear looks like its pretty worn. There is some pitting on the middle journal also.
90 IROC
SuperRamed 406
Trickflow 23* heads
Old Nov 9, 2001 | 03:39 AM
transfixleo's Avatar
If the valve inside is free and the shaft shows NO wear, then you can just have the gear replaced and reuse the original.
Old Nov 9, 2001 | 07:44 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
The gear is pretty worn...shouldnt the gear on the governor in the tranny now work on my original?
thanks!
90 IROC
SuperRamed 406
Trickflow 23* heads
Old Nov 10, 2001 | 12:41 AM
Nordbert's Avatar
Always replace a governor gear with a new one. They are very inexpensive and easy to install. One from a tranny shop is usually less than one from a dealership.
Old Nov 11, 2001 | 12:32 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Well I put my old governor back in. The car shifts great now...The shift points are where they should be. I dont have to manualy shift it like i did before. And when IM just driving slow it shifts at a low speed. But when I start to get into the throttle some it holds second to about 4200. WOT shift points are 5200 now up from about 4000-4200.
I compared the two governors and the original one looked as good as the one the mech put in it. The only thing was the plastic gear on mine was worn. So I tapped out the roll pin and was installing the one from the rebuild. On the last blow of the hammer i hit the gear like a dummy and smashed it. So i had to use the worn one. I will have to get a new one.
Just wanted to let you guys no how it turned out.
Mike
90 IROC
SuperRamed 406
Trickflow 23* heads
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
