l98 cam in an lb9
Old Jan 21, 2003 | 07:13 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
l98 cam in an lb9
what kind of results do u see with a l98 cam in an lb9, or are they the same? also, what kind of results do u see with a lt1 cam in an lb9? ...the lb9 would be all stock for the most part...thanks for the help
Old Jan 21, 2003 | 07:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Some years, some cars, the LB9 & L98 cam is the same. If you have a peanut-cam LB9, the other cam is a significant upgrade. But, if you're changing the cam, there's better things than a L98 one; look at www.compcams.com catalog, go to the very last page of SBC cams, look at the "302" grind.
Old Jan 22, 2003 | 12:14 PM
Drakar's Avatar
RB has it the LB9 got the L98 as it's "HOT CAM" it was part of the G92 pack only avail in a 5speed 305 combo.
Other wise I would just get a nice Compcams
Do a search and see what most people run, you should be able to find someone with your setup and a cam that runs decent on the board.
Jorlain
Oct 8, 2015 01:57 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
masonta
Sep 1, 2015 06:40 PM
