What tools are needed for removing a distributor, and how is it pulled?
Old Jan 24, 2003 | 07:39 AM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
My 92 V6 (3.1L) Camaro needs its distributor out, because the faulty pickup coil needs to be serviced. I have a Haynes manual, which gives an explanation how to do it, but I want some specific instructions because the Haynes manual isn't exactly reliable. What tools do I need to do this, will a socket and a wrench be all that I need? Can you give me tips on how to keep the timing correct, as that is my main concern. I know a good deal of info about cars, but never messed with removing a distributor, any tips are greatly appreciated.
Old Jan 24, 2003 | 08:02 AM
ede's Avatar
ede
just remove the hold down clamp and pull it up and out, no special tools required
Old Jan 24, 2003 | 09:18 AM
Damon's Avatar
Make sure you don't drop the oil pump driveshaft down into the motor. It's a hex shaft that usually comes out with the distributor shaft, but it can fall out. Just be careful- you don't want to go "magnet fishing" for an oil pump driveshaft!
Also, replace the oil seal (o-ring) at the top of the distributor shaft while you've got it out. The o-ring gets hard and brittle and starts leaking after many heat cycles.
Old Jan 24, 2003 | 10:24 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It does?
Old Jan 24, 2003 | 11:57 AM
ede's Avatar
ede
not sure about 60* engine but the 90* v6s are just like a SBC and the oil pu,p drive shaft can't come out with the distributor, only hex shaped drive shafts i've saw were on fords.
Old Jan 24, 2003 | 12:19 PM
Vader's Avatar
Yeah, and I've twisted off some of those weenie little hex shafts on 289s and 302s. That really bites, because the engine will still run.
AFAIK, the oil pump shaft on a 60° V-6 is retained just like on he V-8s. Unfortunately, my manuals aren't very clear on that.
Old Jan 25, 2003 | 12:15 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Might want to make a mental note of exactly which way the rotor is pointing, and make a mark the dist shaft down by the hold-down clamp so you can get it back in there the way it came out. Ign timing should come out pretty close, but should be re-checked anyway.
A hint: don't leave the hold-down clamp and the bolt laying down there while pulling out the dist. They WILL fall into the hole if given the slightest chance!
Old Jan 25, 2003 | 04:26 AM
Rob116's Avatar
Car: 1986 Z-28 Camaro
Engine: 355
If you can get a hold of a distributor wrench for cheap, pick it up. I wouldn't go without mine!
Old Jan 26, 2003 | 01:59 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
distributor wrench's rule
Old Jan 26, 2003 | 08:29 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
nope, 60* V-6's use a strait(no sleve)hex shaped shaft(I've used a socket on a drill to prime them) and it will most likly come out with the distributor, it may be stuck in the bottom (in the gear), if it dosent come out with the dist., I'd make sure it is in the oil pump with a socket on a drill(I tape the socket to an extension and then use one of those adapters in the drill) spinning clockwise , if oil starts coming into the hole arond the shaft, it is in the oil pump
Old Jan 26, 2003 | 12:09 PM
Vader's Avatar
Dave,
Thanks for the tip. I know the odd-fire Chevy V-6s are like the V-8s, but didn't have a clue about the 60° engines.
Old Jan 26, 2003 | 01:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you do a search on the V6 board, I've put up a ton of messages regarding the 2.8/3.1's distributor. The Haynes is dead-on about the distributor removal, by the way. You might want to bring your engine up to #1 top dead center, just to make life easier, and to check your balancer.
Remove the coil wire from the dist cap, remove the #1 plug (remember it's front Passenger side cylinder, for our 2.8/3.1's!!). Turn the crank clockwise (as viewed from front bumper) with a socket on a breaker bar, while you have your finger over the #1 plug hole. When you start feeling pressure on your finger (compression stroke), take your finger away, and put a phillips' head screwdriver gently into the spark plug hole, to touch the top of the piston. Don't scrape the sides of anything in there. Turn the crank a bit more; when the screwdriver stops raising, you've found TDC of #1.
When you get to #1 TDC, check your balancer to make sure the outer ring hasn't slipped. The balancer's timing mark should line up exactly with "zero" on the timing degree indicator. If it doesn't, the rubber isolation ring has probably deteriorated, allowing the outer ring to move as it wants- and your timing will be off when you set it later.
Distrib rebuild is a 10 minute job; all the work is removing it and installing it. Remember to clean up the gap between the reluctor and pole pieces. With the distrib in your hand, spin the gear. You'll feel some slight pulses. This is the magnets of the reluctor (spinning disc at top of distrib) lining up with the "fingers" that are fixed to the top of the distributor. By using a valve feeler gauge, you can bend all the fingers an even distance IN towards the reluctor disc. The pole pieces, obviously, shouldn't touch. When you're done aligning the pole pieces to the reluctor tabs, spin the distributor gear again- the "pulsing" will feel stronger to you. This is good; it's a stronger signal to the pick-up coil.
Oh, one more thing; it's okay for the pole pieces to have some surface rust on 'em; no electricity jumps through them. It's just magnetism. You could clean up excessive rust at the tips of the fingers, where they line up to the tabs on the reluctor disc... but you probably won't have excessive rust. Don't go sanding the hell out of 'em!
IROCZ1989
Jan 24, 2016 03:55 PM
TheExaminer
Aug 25, 2015 07:34 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
3rdgenparts
Aug 8, 2015 07:09 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
