Car drives itself practically
Old Feb 2, 2003 | 01:38 PM
pmurray3's Avatar
I have A 91 RS and the tach reads very high. When I start to drive the car i can go up to third gear without touching the accelerator. I have heard a few things from friends to try but always find the best info here. Any ideas? I am getting a error code. The thing about that is say if I start the car and get on the highway quickly and am moving fast it doesn't come on, but the second i slow down to exit the off ramp on comes the service engine soon light? When I get my car up here at school in a few days i am gonna attempt to display the code although I am not positive where the dlc connector is?? below the steering wheel I believe? Any help or ideas appreciated.
Old Feb 2, 2003 | 02:19 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
The connecter is right in front of your right knee when driving. check the codes and lets us know what comes up. Then it will be eaiser to help you.
Old Feb 2, 2003 | 04:51 PM
pmurray3's Avatar
Thanks, I figured That after I got the code It would be easier for people to help But i just decided to post anyway.
Thanks again
Old Feb 2, 2003 | 08:10 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
left knee isnt it? at least in my car
Old Feb 2, 2003 | 08:12 PM
llvll4l2c91350's Avatar
Next to the fuse box on my 91.
Old Feb 3, 2003 | 07:24 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
right knee ! .... is it different in a T/a ?
mine is on the right
Old Feb 3, 2003 | 07:41 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
On my SC the aldl is on the right.
Old Feb 3, 2003 | 08:06 PM
TekViper's Avatar
Engine: 3.1L v6
weird i thought they were all on the left like my 90 firebird.
Old Feb 4, 2003 | 11:44 AM
Vader's Avatar
First, you'll need to acquire a GM OBD I ECM Diagnostic Trouble Code Retrieval Tool (commonly known as a paper clip to TGO members). You'll also need to have a Diagnostic Trouble Code recorder. I use a 3¼ x 5 ruled index card and genuine cedar #2 pencil, but I suppose any note pad and writing instrument will work for a first-timer.
With the engine and ignition turned off, locate the ALDL connector under the dash, just to the right of the steering wheel in the driver's foot well area. There should be a small rectangular cover over the access hole in the lower dash trim.
Insert a tool as described above (paper clip) into the 'A' and 'B' terminals on the ALDL connector:
WITHOUT STARTING the engine, turn the ignition to the "RUN" position. Watch the Malfunction Indicator Lamp (MIL) and it will begin to flash. This is also commonly called the "Service Engine Soon" or "SES" lamp. The first code will flash three times, and will usually be a code '12'. This is encoded by one flash of the lamp, a brief pause, then two successive flashes of the lamp. Each code will repeat three times, so you should see a "Code 12" flash three times. Any other error codes will follow in numerical order, and each code should flash three times. After all codes have been displayed three times, the "Code 12" will again flash three times, then all other codes will follow as described earlier. This cycle will continue until the jumper is removed or the ignition is turned off.
After you have made a note of all error codes, turn off the ignition and remove the jumper immediately. If you forget to remove the jumper and attempt to start the engine with it in place, you could damage the ECM. For this reason you should remove it immediately.
Once you have a note of all error codes, check this file for the decoding:
GM Error Codes.pdf.
You'll need Adobe Acrobat Reader to open/print the file. (See link below.)
Old Feb 4, 2003 | 12:21 PM
pmurray3's Avatar
Thanks a lot Vader will do. I appreciate the effort and the humor you put into helping me.
Old Feb 4, 2003 | 02:55 PM
TekViper's Avatar
Engine: 3.1L v6
the tech article says to put the paer clip in pins A and M according to your diagram, or 6 and 12 as the tech article says. is it different for different cars? i want to see if i have any codes but dont want to damage it by shorting the wrong pins. i have a 90 firebird
Old Feb 6, 2003 | 06:27 PM
chymos's Avatar
IIRC after a certain year GM changed the pinout, which means that up to a certain year, one is correct, while from that year on the other is. not sure which is for what years, though
Old Feb 6, 2003 | 10:25 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
If it's OBDI with a 12 pin ALDL connector, it's always A and B. This trick is not possible on any car with either partial or full OBDII system and a 16 pin ALDL connector....basically anything 1996-Present and some 1994/1995 vehicles with partial OBDII.
Old Feb 26, 2003 | 11:48 AM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
how high is your idle? sounds to me that your idle is to high if it moves buy itself. and you say the tach reads real high.
Old Feb 26, 2003 | 12:11 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
look into checking for vacuum leaks or a bad/stuck IAC if the codes don't turn anything up.
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
86IROC112
Aug 17, 2015 02:00 PM
kyleb24
Aug 15, 2015 08:24 AM
