Heating works only on high/defroster mode!
Old Feb 16, 2003 | 12:13 PM
84 Challenge's Avatar
The heating/air works only in defroster mode. The defroster blows hot air when the engine is heated enough. It'll also blow cold air when the temp selector is on the cold side. Suggestions anyone before the dash is removed. Please!
Thanks,
Brandon
Old Feb 16, 2003 | 12:33 PM
1986redbird's Avatar
check for a broken/disconnected vacuum hose, the default setting without vacuum is defrost. there is an accumulator mounted on the firewall just above the brake booster, that is where most of the hoses come off of.
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No vacuum coming to the selector switch... maybe somebody "cleaned up" under the hood a little too enthusiastically, or the vacuum selector itself is bad.
Old Feb 16, 2003 | 12:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Vac selector was the culprit on my 85.
JamesC
Old Feb 16, 2003 | 04:23 PM
Where's the vac selector located?
Old Feb 16, 2003 | 04:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
AC control head
Old Feb 16, 2003 | 05:21 PM
Really? Those things can go bad? No problem! Will just get another one.
Brandon
Old Feb 16, 2003 | 05:24 PM
Only thing I found was this black tube looking thing with one wire and a small hose coming out of the same end. The wire is connected to the underside of the hood. The hose is cut. Is this what you're talking about?
Brandon
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyle5647
Aug 15, 2015 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
