power estimation
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
power estimation
idonno where this goes as far as boards, but about how much power will this make?
92 305 with tbi
rebuilt top end with crane cams compucam (about 2 over) and valve train, and ported heads
underdrive pullies
custom cold air intake
hypertech thermotech chip and thermostat
lightweight flywheel
hooker competition headers, y-pipe, no cat, flowmaster muffler
new plugs, wires, and ingition stuff
will this get me near 300hp??
also... what can i do as far as throttle body and intake upgrades other than go carb or mess with all the tpi wiring?
92 305 with tbi
underdrive pullies
Swap in a 350 or spend Big Bucks on the 305 and still
not get the same results as with a 350. The 305 TBI is not the best engine to start with in the first place. Also why is 300hp a magic number??
Car: Camaro RS
Engine: TBI 5.0L
Cause my mom wont let me drive a car with more than that while i live at the house... why someone that would limit it would limit it that high idonno but....
how much average would it cost (engine and all) to swap in a 350 with efi?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you could just wait til you are out on your own, and then mod it to yoru hearts content.
and 300HP is a tall order on a TBI 305. i am doing heads/cam/intake/exaust and hoping for 225 :-(
Car: Camaro RS
Engine: TBI 5.0L
so your sayin that the new hondas make more hp than my car is even capable of? that blows...
wat about like aftermarket tpi? like wat holley or whoever makes for cars that werent even efi in the first place..... how much could i make with that?
Car: 1990 Camaro RS
i am not saying it can't be done. it is just not something that a factory TBI 305 will do without some major modifcations.
but at 225HP you will have probably 300lbs/ft or more. which a honda will NEVER have.
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Let me see stock your car came with 170hp. It has a tiny cam and the worst production heads gm has ever used. You are changing the heads and the cam and only expect to gain 55hp? you must be using a tiny non roller cam...
Car: 1990 Camaro RS
well, i was talking 225 to the tires, which is 250 or so crank.
and i dont' want a huge cam, i would still like a fairly smooth idle.
but regardless, i would like to see 300HP 305 TBIs - do you have one?
Keep dreaming. My opinion with that 305 TBI. Here is what you need......
Car: 1990 Camaro RS
Originally posted by Z28DJP1987
drifter-x
drifter-x
Car: 1990 Camaro RS
if only 45 cubes didnt cost 3g
you should be able to pick up a nice short block or long block for alot less than 3k.
Car: Camaro RS
Engine: TBI 5.0L
how much would a fully ready engine be? i dont know enough or trust myself to put one together so if i do get sompin new itll have to be like turn-key or watever...
Car: 1978 Chevrolet C10
Transmission: Turbo 350
**** i put all together about $1300 into my camaro's 355, 350 .30 over, cam install, listers, ported heads, and an edelbrock performer intake and 600cfm carb, and it puts out 213 and 307 at the wheels, through the slightly built auto, 700R4
PS
Ill sell you my engine, complete for $2500, lol
PS
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
check this out..
http://www.hioutput.com/tech.html
Car: 1990 Camaro RS
7200 402 287 .479
they spun a 305 to above 7K to get that. i for one am not going to run my L03 that high.
Engine: 406
but these # look pretty good.
4250 356.2 288.2
What would be wrong with that?
Why people insist on choking a performance engine with FI is beyond me......
4250 356.2 288.2
Engine: 406
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Change out those stock heads man that you got on that car. They are peices of ****...although good for some low end torque...for all out power and and to have atcual top end you'll need new heads. I threw on some Monte Carlo SS heads and Damn huge difference. According to many hp estimators (simple and also pretty advanced ones), also the G-tech pro thing, racing againts other cars, etc. Seems like my motor at the moment has about 240-260hp...which is sadly...about the hp of a stock L98 *slaps forehead* haha...and ofcourse alot less torque then a L98.
sailtexas186548
Aug 24, 2015 10:11 PM
