Flue Pump Blues
Old Feb 18, 2003 | 01:54 PM
TMoNeE's Avatar
Car: 87 Z28
Flue Pump Blues
Ok, I am fairly certain that my problem may be my fuel pump. If this is the case, what's the process of replacing it. Is it in tank? Someone give me some info on this please, thanks.
Old Feb 18, 2003 | 03:02 PM
IROC57TPI's Avatar
Well, are you sitting down?
First thing to do is have someone look into your throttle body while you're cranking the engine and make sure that its not getting fuel before proceeding with the fuel pump job.
If it indeed is not getting fuel then hopefully you have access to a hoist and air tools. If not you're in for a hell of a job.
Heres a brief procedure:
MAKE SURE THE TANK IS AS EMPTY AS POSSIBLE. SIPHON IF NECESSARY.
1) Lift car as high up as you possibly can. You will need all the room you can get. MAKE SURE ITS SAFELY SUPPORTED.
2) Take off the rear wheels.
3) Open fuel door and remove all screws retaining the plastic panels and the filler door itself and remove the filler door and plastic cover panels around the fuel filler neck. Also remove gas cap.
4) Unbolt rear panhard bar from its mount on the passenger side of vehicle. Lower or completely remove panhard bar. Also remove the upper bolt to the bar support. Its right above the last bolt you would have removed.
5) Support rear axle. Unbolt rear lower shocks from rearend.
6) Remove retaining bolt that holds brake T to the rear end.
7) Lower the rear end down slowly and remove rear coil springs from both sides.
8) Unbolt and or remove muffler and tailpipes.
9) Remove aluminum shield (7mm bolts).
10) Unfasten fuel lines from tank (drivers side)... Unplug wiring harness from body.
11) Unbolt bolts retaining the gas tank straps and let the tank down.
12) Pull down hard on the passenger side of the tank and bent the filler tube down and slide the tank out.
Now comes the dagerous part. You are going to have gas fumes all around so no smoking or any other open flames!
You will need a tool or some skills with a hammer and screwdriver to remove the retaining ring that holds the sender in the tank. Spin the ring until the tabs line up with the opposite side and pull the sender out and replace the pump/screen in the bottom.
Careful not to bend or force anything. That will screw up your fuel gauge like the previous owner of mine did
Hope this helps. This is not for an amateur.
Old Feb 18, 2003 | 03:28 PM
TMoNeE's Avatar
Car: 87 Z28
Ouch! definately not for me, how much does it cost to have a shop due this. If I provide the pump
Old Feb 18, 2003 | 03:34 PM
TMoNeE's Avatar
Car: 87 Z28
Old Feb 18, 2003 | 03:41 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
its really not that hard it just requires some patience and the right tools.. took me 25 mins to do mine and i've never changed an intank pump in a 3rd gen before
Old Feb 18, 2003 | 03:52 PM
89RsPower!'s Avatar
also i forgot to check to see if search is working agian, however i believe some people here have rigged up old style mechanical fuel pumps after their electric ones went dead, from what i understand you just hook the mech pump up and it will pull fuel through the old burnt out electric pump and you have to add a vented gas cap... it sounds like it should work in theory but i have never tried it. This fix is reasonable if you are running a carbed car but i dont believe you would be able to get enough pressure out of a mech pump to support any type of fuel injection
Old Feb 19, 2003 | 11:40 AM
TMoNeE's Avatar
Car: 87 Z28
A shop where my friend gets all his work done quoted me 300 bucks to do my pump, good deal?
Old Feb 19, 2003 | 02:05 PM
IROC57TPI's Avatar
Well the pump and pickup sock are usually $50-$75, and the labor calls for 5.2 hours the last I checked. I would say that $300 is an excellent deal. Hopefully your exhaust isn't welded on or the price will go up if they have to cut and re-weld.
Old Mar 2, 2003 | 07:53 PM
igotslicksNchix's Avatar
HOLY CRAP! we did a pump on a blazer.....it wasn't that hard at all. Anyone know the procedure on a 1990 chevy corsica? it needs to be done....
Old Mar 2, 2003 | 08:04 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
Ya, I paid $300 and change to have this done on mine. I had nor the time, knowledge, or tools to do something like this. Just get it over with. Good luck dude.
Glowsock
Jul 24, 2025 03:15 PM
z28_AJ
Aug 27, 2015 08:59 PM
Linson
Aug 21, 2015 02:12 PM
theurge
Aug 21, 2015 12:46 PM
mustangman65_79
Aug 8, 2015 01:18 AM
