32 valve heads
Old Mar 1, 2003 | 01:45 AM
89firechicken's Avatar
32 valve heads
there were some people tring to put either dominion or the areo heads on. well my question is was that sucsessful? how well does it run and what did you have to do to get it to work? i plan on biulding my new motor with these heads so if any one has some advice that would be cool.
Old Mar 1, 2003 | 04:39 AM
25THRSS's Avatar
might wanna put this in a forum about the engine
Old Mar 1, 2003 | 04:47 PM
Vader's Avatar
Is this on a straight 8? 32 valves would be 8 valves per cylinder on a V-8. There would be so much valve stem in the way you wouldn't get squat for flow from the 5/8" diameter valve faces.
Old Mar 1, 2003 | 05:17 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What? 8 valves per cylinder X 8 cylinders = 64 valves
Old Mar 1, 2003 | 05:52 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yea they should be call 16v heads but since there are two heads it sounds more impressive to combine the numbers same goes for quad cam on this setup.
These would rule to have but I dident win the lotto yet did you?????
Old Mar 1, 2003 | 07:08 PM
no i ment 16 valves per head 4 per cylinder on a v8
Old Mar 1, 2003 | 07:18 PM
Vader's Avatar
Personally, I like the one-valve design, like the rotary valve plate on a two-stroke Suzuki. The flows on such a design would be phenomenal if the materials that could tolerate the heat and pressure demands existed. I've got a working 3D AutoCad drawing of the head in action, along with the partially eliptical (kidney-shaped) gear drive.
We really should be concentrating more on non-reciprocating engine development, anyway.
Yeah, 32-valve "heads" would be a 64-valve V-8, but that's what he said.
Old Mar 1, 2003 | 11:14 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
vader, I remember a set up where the typical poppet valve was replaced by a rotary valve. The heads looked like dohc heads but instead of cams it used a shaft with ports for valves. Is this the setup you're talking about?
Old Mar 2, 2003 | 11:17 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
rotory valve heads
And you thought the 16v heads were expensive.
Old Mar 2, 2003 | 12:20 PM
slayer2000's Avatar
Car: 1990 GTA
yep those were what I was talking about.
Old Mar 2, 2003 | 12:59 PM
bigals87z28's Avatar
Car: Check The Sig
HOLY CHIT... THERE RIGHT DOWN THE STREET FROM ME!! omg... Wall NJ is like 10 mins away from my house.... I gotta go on a tour... i might see if i can get the Dean of Engieering to make a trip out of this!!! this would be awesome! oh man oh man.. when i go home for break.. im gunna go check this place out.
gta90
Sep 15, 2015 04:00 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
