Dual Snorkel Question
Currently I have the CAI that i made out of a K&N type filter and 3" pvc. I was reading and IM pretty sure ill get more air/gains from a dual modded snorkel set-up. Does anyone know where I might find a dual snorkel?
Jesse
Jesse
I found one but the person said "Are you talking about the type the Iroc's and the 2.8l engines had? If so then I have one for ya w/ MAF sensor if you want it. I'd say$60.00 w/MAF or $45.00 w/o MAF. Let me know."
Im not sure what cam on those. Im looken for the kind that requires two filters
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
this is where i got mine, had to modify it some for sensors and clearing the dist, then had to do some major work to run the 4" hoses, im happy with it http://www.ramairbox.com
call the guy , hes cool , hell set ya up and is very personable, not a shmuck that just wants to sell ya something and doesnt have time to talk
Car: currently thirdgenless!!!
Jesse,
What kind of engine do you have?
The intake that sits on top of the radiator with 2 K&N's is usually for the TPI engines. The dual snorkel is for the throttle body LO3 engine and is a copy or duplicate of the L69 HO intake from approx '84 or '85 (I may be wrong on these years).
So, what you are looking for is the MPFI air box?
I have a 2.8l v-6 MPFI air cleaner assembly, with the air temp sender in it, and I think I also have the air hose, and the MAF sensor, It might even have some filters in it to.
I got it out of my old 85 Camaro.
pm me if you want it, I'll make you a deal on it.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The 2.8L/3.1 MPFI & the TPI V-8's use the same dual filter setup, the round end that connects to the TB is a little different between 6's & 8's though.
Car: check
Engine: check
Transmission: check
Originally posted by jesse23
i have a 3.1l 91 RS
Its MFI so basically TPI
It should fit am i right?
i have a 3.1l 91 RS
Only other thing is a filler piece to take the place of the MAF. I used a soup can for a while then made a nice one from a piece of PVC. Search the V6 board, there are even pics of the air intake posted.
RBob.
Car: 88 IROC Convertible
Transmission: Raptor 700
yea the v6 mpfi and the v8 tpi's used the same intake setup with the dual snorkel. go to the junkyard and just pull one, i've gotten two already that way
Brinkkl2000
Aug 4, 2018 08:29 AM
