Retrofitting TPI heads on older engine + other questions
Old Apr 3, 2003 | 01:47 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i have removed the 882's from my 70's era rebuilt 350. i have placed a top of it a set of stock rebuilt iron 89 L98 heads. i have a Comp XE268H (.477 .480) in that motor. since i have a hydralic flat tappet cam, i do not need self aligning rockers right???? i will be using new stamped steel rockers (pre-86) on that motor. any problems with that cam, the and those heads? anything i'm overseeing??? will an 89 MAF tpi setup have too many problems with that cam, since i am retrofitting tpi on this motor as well. please help!!! thanks again.
Old Apr 3, 2003 | 02:40 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
No the heads require self aligning rockers, not the cam. The MAF TPI computer may not like working with that cam.
Old Apr 3, 2003 | 05:40 PM
Car: 1988 IROC-Z
. so i will have to buy new rocker again. oh well. i thought the MAF computer wouldn't have too much of a problem? oh well i guess i thought wrong??
Old Apr 3, 2003 | 05:56 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I think that if you use guide-plates you may bealbe to use the older rockers. I'm not sure if you can use guide-palte on the newer heads though. But i do know you can't run guide-plates and SA rockers at the same time.
Old Apr 3, 2003 | 06:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look at the heads, specifically the holes where the push rods go through. They may be either little narrow slots that fit tight to the push rods, or large holes that let the push rod wander around in there.
If they're slots (they won't be), you MUST use old-style rockers, and you MUST NOT use either self-aligning rocker or guide plates. If they're big holes (which they should be), you MUST use either SA rockers or guide plates BUT NOT BOTH, and you MUST NOT use old style rockers.
The rockers must have ONE AND ONLY ONE of the 3 possible guide methods installed and in effect: either narrow slots and no guide plates and old-style rockers; or big holes and guide plates and old-style rockers; or big holes and no guide plates and SA rockers.
Old Apr 3, 2003 | 06:24 PM
Car: 1988 IROC-Z
the heads are 14096217 castings. the have the "canted"4 center bolts(87+ centerbolt VC). here's a pic. what type are they guys? i'm not even a head novice.
Attached Thumbnails Retrofitting TPI heads on older engine + other questions-head.jpg
Old Apr 4, 2003 | 10:52 AM
Car: 1988 IROC-Z
anyone? i guess these have the slots and do not require SA rockers right?
Old Apr 4, 2003 | 01:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You are correct. Those are indeed the narrow slots. Your only correct rocker option is old-style rockers, with no guide plates.
Here's a head that's set up for guide plates. (Not a stock one though) It would also be possible to use no guide plates and SA rockers on this.
Attached Thumbnails Retrofitting TPI heads on older engine + other questions-top-head.jpg
Old Apr 4, 2003 | 02:16 PM
Car: 1988 IROC-Z
thank you very much.
"woo hoo"
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BBSDesigns
Aug 11, 2015 07:39 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
