My car makes a Clunking noise when it shifts, can anyone help?
Old Apr 4, 2003 | 04:22 PM
1987-396-IROC's Avatar
Car: 1987 IROC-Z
Engine: 4 bolt 383
Hey guys im new to the boards and i have a 1987 IROC and ever sense i had my car it has made a loud clunk every time it shifts, it doesnt seem to be hurting performance but its anoying and i still havnt found out what the hell it is, if u guys could help that would be awsome,
Thanks!
Old Apr 4, 2003 | 04:46 PM
Grants85TA's Avatar
Could be your universal joint on the driveshaft or you could have excessive backlash in your ring & pinion gear. I had the same problem and my mechanic replaced my universal joints. Cost about $150.00 with parts.
Old Apr 4, 2003 | 04:57 PM
Car: 1987 IROC-Z
Engine: 4 bolt 383
yea same thing i was thinking my mechanic said the u-joints were good but i think maybe he didnt look good enough.
Thanks man.
Old Apr 4, 2003 | 05:00 PM
Car: 1987 IROC-Z
Engine: 4 bolt 383
did the noise go away or just wasnt as loud?
Old Apr 4, 2003 | 11:15 PM
Grants85TA's Avatar
Went away, feels good not to hear that clunk noise anymore.
Old Apr 4, 2003 | 11:36 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If you mean that it clunks everytime it shifts from 1st to 2nd, and 2nd to 3rd, etc. (and it's an auto, which you didn't say) then it could be the tranny mount.
I've had mine break and the whole car shifted to one side everytime I accelerated. Kind of annoying.
goneracin's Avatar
Mine also made a clunk under hard shifting. After alot of searching, it turned out that the tranny mount at the rear of the trans was bad. It would let the trans flop around under power. Just an idea.
Bob
Old Apr 5, 2003 | 01:22 AM
Car: 1987 IROC-Z
Engine: 4 bolt 383
its a automatic, and i replaced the tranny mount allready its not that, and it doesnt seem to do it when the cars is shifting 1, 2,3,4 but i hear it when i put it in a gear for example-from park to reverse or into drive, it also clunks when it downshifts as i slow down.
Old Apr 5, 2003 | 10:46 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Clunking when going from park to drive to reverse, etc. definitely sounds like u-joints - make damn sure on the u-joints - I seen someone do the pole-vault thing at about 30mph and it wasn't funny! After seeing that car do that flip - I'm definitely in the market for a driveshaft loop!
Old Apr 5, 2003 | 11:42 AM
cfirebird86's Avatar
Car: 86 firebird
Engine: v6
Transmission: 7004r
clunking
mine does that smae things. When ever i put her into reverse. She's an automatic. How much does it cost to get the universal joint fixed in an 86 firebird?
Old Apr 5, 2003 | 12:15 PM
jimmy_mac's Avatar
u-joints are not very expensive pieces. The key to getting them out is melting the inpregnated junk the factory has injected inside them with a torch. once you get them hot enough that you see this stuff melting out you can wack them out with a socket you don't need anymore and a hammer. I broke a vise trying to get mine out before I found out about the stuff they inpregante them with. But I think they are less than 20 bucks.
Old Apr 5, 2003 | 04:17 PM
Car: 1987 IROC-Z
Engine: 4 bolt 383
ill look into replaceing them, thanks for the help guys.
Old Apr 6, 2003 | 11:46 AM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
i had a similar problem...turned out to be a tranny mount. Mine only clunked when i shifted from park to first or from first to second.
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
MENINBLK
Aug 5, 2015 11:58 PM
