Z won't turnover.
Old Apr 11, 2003 | 03:23 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Z won't turnover.
My car has been sitting for the last 4 months(it started 2 months ago) and it won't turnover now.It now has a new battery and the alternator is a year old so it may not be them. When I turn the key I do hear the fuel pump whine so it's not that.I did notice a 3 things though:1-the service engine light stays on and my power hatch-release button doesn't work. 3 The positive battery cable has these skinny red wires in its' loom that are exposed but it has always been like that since I bought the Z.The cable does however actvates the fuel pump when I have the ignition on and I jiggle that + cable. Any ideas?
Old Apr 11, 2003 | 05:06 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it wont turn over or it wont start?
Old Apr 11, 2003 | 05:18 PM
91Zman's Avatar
Car: 1991 Z28
uhhh..both
Old Apr 11, 2003 | 05:36 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Try jumping it... battery could be dead. If it was 2 winter months, it probably is.
Old Apr 11, 2003 | 05:39 PM
91Zman's Avatar
Car: 1991 Z28
Sorry,I meant to say that I got the new battery yesterday.
Old Apr 12, 2003 | 10:03 AM
Vader's Avatar
Z-Man,
You probably have a connection problem. If you can get the fuel pump to cycle by moving the wires, it's not a good situation. The pump should cycle for two seconds only once when the ignition is first turned on. If you can get it to cycle again by moving the wires, you are breaking the ECM power circuit somehow.
Old Apr 12, 2003 | 11:11 AM
91Zman's Avatar
Car: 1991 Z28
Ok well that answers the + cable problem but what about the others?the power hatch-release button not working(it did before),the service engine light stays on and finally...it won't turnover/start.I have power to everything else too. Neutral safety switch?
edit: I falled to mention,just remembered, that the old battery had a bad terminal the part that the cable connects to.All the jiggling happened when I was trying to tighten the connetion but couldn't really.So i got the new battery anyway.
Old Apr 13, 2003 | 02:10 PM
91Zman's Avatar
Car: 1991 Z28
ttt
Old Apr 13, 2003 | 03:06 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
might be your neutral safety switch - did the trunk work when you started it two months ago? i would replace that if i was you...
Old Apr 13, 2003 | 03:12 PM
91Zman's Avatar
Car: 1991 Z28
yes it did work then.i'll take it out later today if i have the chance......thanks
Old Apr 13, 2003 | 05:33 PM
Tyler-88's Avatar
damn, i have the same problem...
https://www.thirdgen.org/techbb2/sho...hreadid=170638
https://www.thirdgen.org/techbb2/sho...hreadid=170211
turns out my fusable links fried beside the starter. ive replaced them all, but one keeps frying when i hook the battery back up. i have no friggin idea whats going on. and the SES light always on, i hope im wrong, but i herd that might mean a fried ECM
Old Apr 13, 2003 | 05:40 PM
91Zman's Avatar
Car: 1991 Z28
Well my SES light goes out after I turn on the ignition so thank *** for that.Sorry to hear of your misfortune.
Old Apr 16, 2003 | 06:56 PM
91Zman's Avatar
Car: 1991 Z28
ttt
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
