Anyone know where i can get a 90-92 dash?
Old Jul 26, 2000 | 04:28 AM
SmokedU's Avatar
Just wondering if anyone knew where i could order a complete 90-92 dash. the center console and everything (is it needed?). i might be buying a sorta messed up 85 Z28 from someone for a few hundred, and want to upgrade the current dash to a 90-92. I considered leaving it there and just buying some autometer guages to replace them, but i dont really like the design of there speedos and really like the look of 90-92 dash. im sure your all familiar with what 90-92 dashs look like, but im sure youll see what i mean from these pics.
http://www.geocities.com/red90_1LE/IntDsh.jpg
http://www.geocities.com/red90_1LE/IntPS.jpg
http://www.geocities.com/red90_1LE/IntDS.jpg
http://www.geocities.com/red90_1LE/Odometer.jpg
pretty sweet huh
Old Jul 26, 2000 | 04:30 AM
SmokedU's Avatar
Oh yeah, and this would even include the steering column. I hope you guys can help, do you think nextgenparts would have it? or order it directly from GM?
Old Jul 26, 2000 | 07:16 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I would stay away from Nextgen or GM. If you do find the parts...and I'm pretty sure Nextgen has some of them....it would be way too expensive. Keep browsing through the archives and you should stumble across some links to sites with what you are looking for at better prices.
Old Jul 26, 2000 | 07:27 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
This isn't going to be just a simple plug&play swap... you need to do some research on replacing a mechanical speedometer with an electronic one first. The 85 Camaro used a mechanical speedometer and IIRC they went to using the electronic speedo in 89 or 90 (the Firebirds went electronic in 86). There is an article in the tech section about performing this swap for a Firebird, (I will be doing that exact swap in the near future), but it shouldn't be too different from doing the same swap with a Camaro.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
Veiw my car at: http://www.geocities.com/transam85tpi/TransAm.html
Old Jul 26, 2000 | 07:44 AM
SmokedU's Avatar
Pukka: yeah, i went to a GM site and they want 25% OVER retail.
Kevin: I could imagine it wouldnt be plug and play, although it has been done. Im thinking that i should order the dash (if i can find it) and then work out the bugs on the way.
Old Jul 26, 2000 | 08:48 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Where are you at??
There is a great GM only junkyard out here.
www.gmsportssalvage.com
They have a ton of parts for all gens. Good stuff too.
ASE Mechanic/Machinist/Smog Tech
RTKTGTR 1999 NBM T/A, flowmaster,FRA,Pro Kit,BMR STB, polished calipers.
1986 Chevy 3/4 ton pick up,flowmasters,4.10s,
1981 corvette FOR SALE
1995 ZX6R,Yosh,D207s
GO #3
[This message has been edited by Engineboy (edited July 26, 2000).]
Old Jul 26, 2000 | 12:12 PM
tuc007's Avatar
thats gmsportssalvage.com
1991 Cavalier Sh*t *** Beater Car
(SOLD)
1988 Camaro SC w/Z28 Grille, 305 TBI
Mr. Gasket Non-Drop
Open Element Air Cleaner, IAT relocated, JVC CDPLAYER and REAR SPEAKERS - STOLEN FROM MOMS LUMINA
blue interior lights
"Yippy-kah-yaay motherf*cker"
Old Jul 26, 2000 | 12:22 PM
Matt84TA's Avatar
TA creations is pretty good...
www.tacreationsusa.com
Old Jul 26, 2000 | 12:33 PM
SmokedU's Avatar
Engineboy, im in MI, i could probly check copartsfinder.com or call around. Im sure eventually ill find it, its just a question at what price. Im almost sure nextgenparts would have it.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
