Throttle body to...
Old Apr 26, 2003 | 07:14 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
Throttle body to...
Quick, simple question. Just below where the pcv hose plugs to the throttlebody, there is another "male" connector. Where does this connect to? I can't find any loose hose and I must not have drawn a diagram when I tore the top of the motor down (I drew pictures or took photos of everything else).
BTW, it is an 88GTA, 305 -stock, with A/C.
I did a search and didn't find anything and any engine bay photos I found weren't any help (neither was Haynes). I have a shop manual but it is the wrong year. I'll pour through that while I wait for an answer here.
Kevin
Old Apr 26, 2003 | 07:54 AM
85TPI400's Avatar
That one, (if it is the one I am picturing in my mind) should have a hose that connects to the smog canister. Located near the pass. side fender.
Old Apr 26, 2003 | 12:57 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
There is a canister up front, right next to the air filter canister. It looks like there is one place to connect a hose on there, except there is a plastic block off piece prohibiting the connection. Is this where it would connect, or am I still loking for something else?
Again, it is the "male" nub in between the pcv connection and the coolant connection on the TB.
Kevin
Old Apr 26, 2003 | 04:32 PM
Vader's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=171651
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
