What do you think blew in my motor?
Old Jul 25, 2000 | 07:37 PM
Trevor 91 Formula
Guest
Posts: n/a
Coming home from work today I started getting smoke coming out of the PCV holes in the valve covers as I have them vented to atmosphere. No smoke coming out the pipes. So I'm thinking I'm getting excessive blowby in a cylinder. I also am WAY down on power and it misses one cylinder every rotation.
But could it be anything else? A valve? EGR?
plates: BLWNWS6
L98 w/ATI ProCharger, 2 core intercooler, 9psi pully. Dynoed at 452 RWTQ
Pro-built Stage 3 700-R4 w/Continental 2200 stall TC.
C5 wheels and tires.
Me, my car and I
"Speed kills but it makes me feel alive" - White Zombie
Crazy street-racing idiot member of the All-Powerful Nor-Cal crew.
Old Jul 25, 2000 | 07:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds rather like a toasted piston. Do a compression check and listen for air escaping on the dead cylinder.
Bummer...
Old Jul 25, 2000 | 07:42 PM
Brent's Avatar
I vote for busted rings/ring lands.
Get a compression test and leakdown test done to help narrow things down.
Old Jul 25, 2000 | 11:47 PM
Trevor 91 Formula
Guest
Posts: n/a
TTT
Old Jul 26, 2000 | 12:11 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd say either intake gasket or cracked piston.
Old Jul 26, 2000 | 12:34 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i say a piston...intake gaskets dont do that...
K&N,MSD Gm Coil,TB Bypass, Flowmasters with Hand Made Tips, Msd Heli-Core Wires, Cold Air Intake, Dynomax High-flow cat
Next:
Cam, Rockers, Pulleys, Msd 6a...maybe a 3.4 crank too..boost torque a bit...
Old Jul 26, 2000 | 12:39 AM
saul 87vette's Avatar
i would have to say ring- piston setup
too bad man your engine is dead
Old Jul 26, 2000 | 10:27 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Sounds like rings are gone or piston to me.
Superman
Rev'n to Seven
Old Jul 26, 2000 | 10:18 PM
zippy's Avatar
Engine: 5.3L
on a supercharged engine, it can push oil out of the valve covers and cause a miss if the gasket is blown at the bottom, just as a naturally asperated engine causes a constant vacuum and miss with the intake gasket blown at the bottom.
deracer
Apr 11, 2016 12:04 AM
Orr89RocZ
Feb 13, 2016 10:04 PM
IroczFan
Oct 6, 2015 10:13 AM
509 camaro fan
Sep 6, 2015 10:43 AM
dyeager535
Aug 28, 2015 08:10 AM
