Blue Smoke from Ex Manifold Area
Old Jul 27, 2000 | 12:52 AM
KornDog's Avatar
89, IROC 5.7 TPI, 89,900 miles--
400 miles ago a crate 350 was installed along with rebuilt injectors. Since then, I have a tap coming from the driver side head area. It sounds like exhuast tap, but the manifolds have been tightened down good. I have checked the hoses going into the AIR tubes and they are tight. It could be vacuum, but when I start the car and watch near the master cylinder, I see blue smoke billow up. Just a puff. Then the tapping starts and continues until I shut down. What am I missing, any ideas?
89 IROC-Z 5.7 stock
95 Geo Metro LSi 3-banger
Old Jul 27, 2000 | 01:30 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
That sounds like an ex. leak.
Just because the ex. manifolds are tight doesn't mean they aren't warped.
Did you use gaskets??
When I install most motors I have the ex. manifolds surfaced and DON"T use any gaskets.
No problems. Never have to worry about gasket leaks.
ASE Mechanic/Machinist/Smog Tech
RTKTGTR 1999 NBM T/A, flowmaster,FRA,Pro Kit,BMR STB, polished calipers.
1986 Chevy 3/4 ton pick up,flowmasters,4.10s,
1981 corvette FOR SALE
1995 ZX6R,Yosh,D207s
GO #3
[This message has been edited by Engineboy (edited July 27, 2000).]
Old Jul 27, 2000 | 03:03 AM
evilho7810's Avatar
Engineboy, are you retarded?
Old Jul 27, 2000 | 07:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
When I build a motor with manifolds, I also follow the factory's good example in that area, and use no gaskets when possible. The temperature variations are extreme between the heads and manifolds, so the parts are constantly changing sizes and moving. Gaskets tend to get chewed up in a relatively short time.
Take engineboy's advice; remove that manifold, make sure the surface is flat, put it back with no gasket, it will be as good as new. Any local machine shop that can plane a head can true the surface for you for very few coins.
Old Jul 27, 2000 | 09:01 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Evilho: WTF !!!???
What did I do/say to make you think I'm retarded??
GO #3
Old Jul 27, 2000 | 04:14 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
alright, youve covered the noise, but ignored the puff of blue smoke at startup.. remember its a new motor.. was it a shortblock? if so did you do anything with the heads before reusing them?
Old Jul 27, 2000 | 04:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Puff of blue smoke out the leak = puff of blue smoke out the tailpipe when the leak is fixed. No mystery there. The valve guide seals aren't perfect (they rarely are), I wouldn't worry too much about it.
Old Jul 27, 2000 | 05:09 PM
KornDog's Avatar
The crate engine was a stock long block. The manifolds were planed down, (maybe not right? I didn't do it) and no gaskets were used. Could this puff be a caused by a manifold leak? If so would it just puff once at start up and not again until the next start up?
Thanks!
89 IROC-Z 5.7 stock
Old Jul 27, 2000 | 05:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup it sure could.
Got that big solid roller cam and blower for your Metro yet?
Old Jul 27, 2000 | 05:26 PM
Drew's Avatar
Korndog, give me a holler some night, someone around here should be able to figure it out.
Drew
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3 @ 98mph
91 RS Convertible
92 S10
Red iroc-z 305
Sep 30, 2015 05:22 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
zayne0
Aug 24, 2015 07:22 PM
Linson
Aug 21, 2015 02:12 PM
theurge
Aug 21, 2015 12:46 PM
