After header install problems
Old Jul 26, 2000 | 06:11 PM
86Trans Am's Avatar
Well got my headers on, new cat, and jerry-rigged it to my old exhaust. (new cat-back is on its way)
The car idles fine, but when you rev it up, it really bogs. The same thing happens when you drive it, if you get on it a little, it just bogs and doesnt accelerate. I'd say it has plenty of back presure, new o2 sensor, the SES came on once when i really got on it and stayed on until it died at the corner and went off when i restarted. What the heck could the problem be?? God dangit, if its not one thing its another, my mechanical confidence was going up for awhile after i got everything apart and was able to put it back together with out any major set-backs....i should have known something would fork up!!!!!
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Jul 26, 2000 | 06:53 PM
86Trans Am's Avatar
I have two weeks to figure this out, someone has to have an idea.
Old Jul 26, 2000 | 07:06 PM
92TRANSAMWS6's Avatar
Usually when you install headers it is also a good idea to switch to a heated o2 sensor.
92 Trans Am/WS6/305/5Speed/T-Tops/Flowmaster Muffler/Ported Plenum
69 Camaro/427-currently awaiting restoration
Since light travels faster than sound, some people appear to be bright until you hear them speak.
Old Jul 26, 2000 | 07:56 PM
Tab92bird's Avatar
What kind of headers are they, and where is the O2 sensor? If it's too far from the engine, you'll need a heated sensor like trans am said.
Old Jul 26, 2000 | 11:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I had the same problem. My 6 and 8 wires were switched.
89 FORMULA 350 Edelbrock Cat-Back March Pulleys
Accel Cap ,Super Coil SLP Airfoil K&N Filter 180 stat , Fan Switch
Taylor 8mm Spiral Pro,TB Bypass ,Energy Sus bushings ,Hotchkis STB ,MSD 6AL ,Edelbrock TES's ,Hi Flo Cat ,Crane AFPR
Old Jul 27, 2000 | 04:02 PM
86Trans Am's Avatar
The headers are SLP 1 5/8 and the o2 sensor is about an inch from where all four tubes come together and an inch or so from where the header meets the y pipe.
Can i get a heated sensor are the local autozone or what, i havent heard of this before.
My wires are not switched, could this be a problem with the mass air flow sensor? I'm going to get the code after class tonight. And one of my coolant lines are sittting right on the mass air sensor.
Any more ideas, headers shouldn't mess with the computer too much should they?/
The code it threw was a 44 - Oxygen sensor lean
Can the oxygen sensor cause this much trouble, I mean the car will go but its about undrivable for any distance. Does this mean i need a "heated" sensor?
thanks
[This message has been edited by 86Trans Am (edited July 27, 2000).]
Old Jul 27, 2000 | 04:52 PM
86Trans Am's Avatar
Old Jul 27, 2000 | 05:10 PM
turfmn's Avatar
How old is your O2 sensor? Did you drop it or hit it with something? What is your fuel pressure set at?
3700lb 86 Z-28. 14.52 @ 93.13mph. 305 TPI
Old Jul 27, 2000 | 07:07 PM
86Trans Am's Avatar
The o2 sensor is brand new, and the fuel presure is about 42psi.
thanks
rocn7roc
Sep 21, 2021 02:16 PM
Wesly_66
Aug 26, 2015 09:55 PM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
drathaar907
Aug 6, 2015 04:20 PM
