cleaning pistons
Old May 1, 2003 | 11:07 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
cleaning pistons
i pulled my shortblock apart today to find it doesnt REALLY NEED pistons, although i may a set..
i was thinking about using a stiff bristle brush (like a toothbrush?) to clean the ring grooves, skirts and tops..
what should i use as a cleaner?..
thanks guys
Old May 2, 2003 | 12:14 AM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
I used a fine wire brush on a bench grinder to clean the carbon. After most of the heavy stuff was gone I used brake cleaner.
Old May 2, 2003 | 12:27 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
did the wire brush scratch the pistons?
id be worried about that
Old May 2, 2003 | 06:20 AM
Tom84L69's Avatar
Car: 84 Z28
it was a very fine wire brush, I wouldn't go at it with a brush with thick, stiff wires. It didn't scratch them at all and I applied a lot of pressure.
Old May 2, 2003 | 07:28 AM
ede's Avatar
ede
i use wire brush on bench grinder too, works great. i'd be very careful about using a ring groove cleaner because they'll remove metal along with the carbon build up. to clean grooves i use a old ring broken in several pieces as a screaper.
Old May 3, 2003 | 12:02 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
thats what i was most concered about...
the top ring in one of my pistons is kinda sledged up in the groove..
i want to get the ring grooves clean, 100 bucks for LT1 rings...sheeeit they better seal good
how can u tell if the rings are good?...i mean when i popped my pistons out none of them were cracked or burnt..
the cylinder walls were shiny and could still barely see the cross hatch pattern..
Old May 3, 2003 | 12:31 AM
radiateu2's Avatar
I used Berryman carb cleaner and a toothbrush worked really well just dont get the Berrymans on your hands. Safe enough for carbs aluminum safe enough for pistons to. A soft brass wire wheel works well too but may leave brass filings behind so rinse them off very well.
Old May 3, 2003 | 02:08 AM
Tom84L69's Avatar
Car: 84 Z28
i would defiantely not re-use rings. Just get new ones and give the block a quick hone.
Old May 3, 2003 | 02:28 AM
radiateu2's Avatar
I agree with Tom. DONOT reuse the rings while you have it apart check the bore for taper. If the taper is only within a few thousands hone it and use new rings. www.enginekits.com should have what you need at a good price and good quality hasting rings
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gta892000
Aug 11, 2019 11:16 AM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
