Will these slicks fit?
Old May 2, 2003 | 07:02 AM
Z28Clone's Avatar
I bought a used set of slicks for $25. I found an 85 Z in the junkyard with a good set of Z wheels. Before I buy them will the slicks fit? Number on the slicks is 26.5/9.0/15. The rims on the Z look stock, but I don't know if they are 15's or 16's.
Old May 2, 2003 | 07:23 AM
ede's Avatar
ede
if you don't know what size wheels you have how is anyone else going to know?
Old May 2, 2003 | 08:18 AM
Z28Clone's Avatar
Well are stock 85 Z wheels 16" or 15"? I thought they only made 15" back then. Someone should know that. I'm just worried about the width.
Old May 2, 2003 | 08:37 AM
todillinder's Avatar
Car: 87 Trans-Am
Engine: 350 cui TPI Chevrolet, MODIFIED
Transmission: WC T-5 with Modifications
Axle/Gears: 3.73 w/ Torsen Diff.
If you have 15" wheels , YES, the tires fit.
todilliner
Old May 2, 2003 | 08:48 AM
Car: 87 Trans-Am
1985 the wheel dim. was 15" x 7". 16" x 8" was a IROC and SCCA Showroom Stock ( 1LE) option.
DRIVE IT LIKE YOU STOLE IT!
todillinder
Old May 2, 2003 | 09:15 AM
Odyssey's Avatar
This guy doesn't even know how what size his wheels are..... but he wants to run slicks. Reminds of riceboys...
Old May 2, 2003 | 10:25 AM
gtabadboy's Avatar
Yes they will fit. I am running the BFG radial T/A with 17" rims. the specs on those are 11" width and 25.7in high. So another .8in higher shouldnt make that much of a difference. Why not measure the height of the tires on your car now. The main issue is the backspacing on the rim. That will judge how far in and out the tire is.
Old May 2, 2003 | 10:52 AM
XChris1632X's Avatar
Car: 83 Z-28
Engine: LG4 305
he is asking how big the wheels are not if the slicks are going to fit on his car but whether they will fit on the wheels that he found. maybe you guys should slow down and read the question before you jump to criticize someone.
Old May 2, 2003 | 01:21 PM
ede's Avatar
ede
i did read it, several times, and i still don't think he said what size wheels he found.
Old May 2, 2003 | 02:20 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
he found some STOCK WHEELS from an 85' z28. those wheels are 15x7. yes, those slicks will be fine on those wheels, however, if you go any bigger (tire wise) get some wider wheels. i will be running a 28x11.5 on some 8" wide wheels and i know that they will work fine.
Old May 2, 2003 | 11:38 PM
Car: 83 Z-28
Engine: LG4 305
thank you mw66nova for answering the question
Old May 5, 2003 | 05:40 AM
Z28Clone's Avatar
Some of you guys are a bunch of idiots. Thank you for those who actually read my post correctly. Now that I know the "STOCK Z WHEELS" will fit the slicks that I bought, I will go to the junk yard, bring a jack with me and remove the STOCK WHEELS from the 85 Z to fit the slicks that I bought.
Old May 5, 2003 | 06:41 AM
mw66nova's Avatar
Engine: 7.0L
whoa there hoss, no need to get on to others cause they didn't read it correctly. you got your information, whether it was from me or not, there is no need to jump on folks back...get your wheels and enjoy your car...atleast you have one to drive.
Old May 5, 2003 | 09:10 AM
gtabadboy's Avatar
Just a little tip... this is not a good way to get help through thirdgen. I see that you have only been a member since dec 2002, and bashing on people that went out of their way to help you- even if they didnt read your real question is not a way to get help or answers to your problems. No matter what, people took their time out to reply to your post in an effort to help you. Take this into consideration before making comments like that.
Old May 5, 2003 | 09:30 AM
Z28Clone's Avatar
My appologies, sometimes reading words instead of speaking with voice can misinterpret the meaning of a conversation. But just reading some people's input made me look like I didn't know what I was talking about (riceboys).
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
fasteddi
Sep 10, 2015 09:32 AM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
